2.2.1
Within Docker image.
Docker.
order log last
admin :2099 {
origins supervisor
enforce_origin
(tls-majority) {
tls {$ACME_CA_EMAIL} {
dns route53
header Strict-Transport-Security max-age=31536000;
(tls-alpha) {
import tls-majority
(tls-beta) {
import tls-majority
(tls-production) {
import tls-majority
(tls-local) {
issuer zerossl {$ZERO_SSL_API_KEY} {
dns route53
(default) {
log
import tls-{$TARGET_ENV}
{$DOMAIN} {
import default
root * /www/app
@exceptProxy not path /favicon.ico /robots.txt
reverse_proxy @exceptProxy http://app:{$APP_SERVICE_PORT_HTTP}
I’m trying to use basic auth without a password:
{$DOMAIN} {
import default
root * /www/app
basicauth /services {
username
run: adapting config using caddyfile: parsing caddyfile tokens for 'basicauth': /etc/caddy/Caddyfile:125 - Error during parsing: username and password cannot be empty or missing
Not providing a password.
I’m trying to secure a route that the Prismic headless CMS will execute on my site. Please view Integration - Documentation - Prismic and read the authentication section in where it says:
The token will be used as the ‘username’ for the Basic Auth flow. The password will be left blank.
