Basic_auth troubles with Cloudflare Tunnel and caddy-docker-proxy
Hi, I’m having difficulty setting up an application service under Docker Compose which makes use of caddy-docker-proxy and Cloudflare Argo Tunnels. Specifically, I am trying to add basic_auth to the root of a Gerrit service container and am encountering 2 different failure modes:
  1. Cloudflare returns a Bad Gateway (502) when I try to access my server and docker compose logs on the Caddy container gives the diagnostic in [1].
  2. The basic auth dialog is never presented and Gerrit redirects me to a login page notifying me that there is no Authentication header and nothing seems to have worked.
There doesn’t seem to be any rhyme or reason as to why either failure mode occurs. Restarting any combination of services can enter a different one.
[1]
caddy  | {"level":"error","ts":1705774799.259001,"logger":"docker-proxy","msg":"Error response from
 server","server":"localhost","status code":400,"body":"{\"error\":\"loading config: loading new config:
 loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler
modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes:
route 0: loading handler modules: position 0: loading module 'authentication': provision
http.handlers.authentication: loading authentication providers: module name 'http_basic': provision
http.authentication.providers.http_basic: account 0: username and password are required\"}\n"}
This error almost suggests to me that Cloudflare is trying to do some kind of liveness check on the connector and can’t get through because it’s failing auth? Do I need to add some exception for accesses from Cloudflare? How would I do that?
v2.7.6 as built using:
ARG CADDY_VERSION=2.7.6
FROM caddy:${CADDY_VERSION}-builder AS builder
RUN xcaddy build \
        --with github.com/lucaslorentz/caddy-docker-proxy/v2 \
        --with github.com/greenpau/caddy-security
FROM caddy:${CADDY_VERSION}-alpine
CMD ["caddy", "docker-proxy"]
Fedora Linux 39 (Workstation Edition) x86_64 with docker-ce 25.0.0
docker compose up -d
Compose file for cloudflared:
version: '3.4'
  cloudflared:
    image: msnelling/cloudflared
    container_name: cloudflared
      - ./config:/etc/cloudflared
    command: [sh, -c, ( echo "cat <<EOF" ; cat /etc/cloudflared/config.yml.template ; echo EOF ) | sh > /etc/cloudflared/config.yml && /usr/local/bin/cloudflared tunnel cleanup $TUNNEL_UUID && /usr/local/bin/cloudflared tunnel --no-autoupdate run]
    env_file:
      - .env
    restart: always
    extra_hosts:
      - "host.docker.internal:host-gateway"
      - cloudflared
  cloudflared:
Compose file for Caddy:
version: "3.9"
    build:
      context: .
      dockerfile: Dockerfile
    image: caddy:v2.7.6
    labels:
      caddy.debug:
      caddy.email: "{env.EMAIL}"
      caddy.acme_dns: "cloudflare {env:CF_API_TOKEN}"
      - CADDY_INGRESS_NETWORKS=caddy
    env_file:
      - .env
      - caddy
      - cloudflared
      - /home/benjaminmordaunt/phorge/caddy/data:/data
      - /home/benjaminmordaunt/phorge/caddy/config:/config
    external: true
  cloudflared:
    external: true
Compose file for Gerrit:
version: '3.7'
  gerrit:
    image: gerritcodereview/gerrit:3.9.1
      - caddy
      - ./gerrit_etc:/var/gerrit/etc/
    labels:
      caddy: neocake.me
      caddy.basicauth: /*
      caddy.basicauth.neocake: "{env.HASHED_PASSWORD}"
      caddy.reverse_proxy: "{{upstreams 80}}"
    external: true
This is entirely handled by docker-proxy labels above.
This is a syntax error, you need to use a dot . not a colon :
Are you sure this env var is defined on your Caddy container?
Good spot - fixed the env var but I think it was using something cached anyway and didn’t make a difference.
As for the HASHED_PASSWORD, I’m defining it in a docker-compose .env and attaching it with env_file now to be doubly sure and it doesn’t make a difference.
No, it just doesn’t get used if you already have a valid non-expired certificate, because Caddy doesn’t need to attempt cert renewal.
Well, it seems like it’s getting replaced with an empty string, so your config fails to load.
