Basic auth multiple users
Caddy v2
Docker container
docker-compose up -d
(AUTH_USERS) {
     basicauth / user1 pass1
     basicauth / user 2 pass2
I’m trying to protect some services of my server with basic auth in a snippet, but I can’t get it working for more than 1 user. I’ve tried to include the basic auth inside the service code, but does not work either.
/caddy# docker exec -w /etc/caddy caddy caddy reload
{“level”:“info”,“ts”:1591689125.9193683,“msg”:“using adjacent Caddyfile”}
reload: adapting config using caddyfile: parsing caddyfile tokens for ‘basicauth’: Caddyfile:21 - Error during parsing: Wrong argument count or unexpected line ending after ‘pass1’
(AUTH_USERS) {
(AUTH_USERS) {
basicauth {
user1 pass1
basicauth {
user 2 pass2
That’s not valid syntax unfortunately. Three things are incorrect.
First, you have a / path matcher, this means it will only match requests to / and not /foo. Path matching in Caddy v2 is exact match. If you omit the / then Caddy assumes * which means “match all requests”.
Second, you can’t have the user/pass pair on the same line, you need to specify them inside of a block, i.e. within braces { }.
Third, you shouldn’t have two basicauth directives because they’ll clash. Instead, you have just the one, but specify multiple users (one per line).
It should look like this:
basicauth {
	Bob <password_hash>
	Cindy <password_hash>
Don’t forget that you need to use the caddy hash-password command to hash your passwords before putting them in your config. Run it like this:
$ caddy hash-password --plaintext some.long.password.string
