http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
but as .dev is a secure namespace and I can access the site everything seems to work.
I thought maybe it’s a cache / cookies problem. So I tried it via curl, other device, and clearing the browser storage. But no auth popup.
Ahh, thanks a lot! I thought I would have to specify the folder, not the route retclative to root… I just started using caddy, so forgive me those rookie mistakes:) I could search a bit on google but you might know the perfect answer, so quick question: Is there any addon which features a better file browser? Like downloading whole folders etc.? Maybe even upload for some users? (It should still be Caddy, not something like filerun)
The project was archived for a time, but recently found a new maintainer!
It used to be implemented as a plugin for Caddy with a standalone option, but it’s now simply a standalone application. To use it with Caddy, you would run it alongside Caddy and have Caddy reverse_proxy to it.
I know this is probably not the right place… but I only see the spinner animation when trying to spin up filebrowser… Any ideas? Do i need to download / make a frontend or something?
I’m not sure what you mean - but no, the frontend is integrated. Is it just a misconfiguration? I’m no expert on that app though, I’m not sure how to help.
Problem was that I proxied only like this reverse_proxy /files 127.0.0.1:8080.
With reverse_proxy /files/* 127.0.0.1:8080 it’s working. Thanks a lot again:) You can close this now @matt.
