Hi, simple question. I am using the latest caddy.
I just want to do a simple redirect
my current code:
redir @http2 /login?redirect=http://{host}{uri}
it does a simple redirect. However, how do i base64 my redirect url?
my current code:
I don’t think this is a simple question. I don’t understand what you’re trying to do. Please fill out the help thread template and elaborate on what you expect to happen.
Base64-encoding the redirect URL will break HTTP clients. The spec does not say it should be base64-encoded.
I do some custom stuff in the frontend before redirecting on successful login myself.
The current login url format breaks my website because I am using a hash router for my website, and if the redirect url contains a hash too, my frotends won’t find the route and won’t work.
I need to be able to encode this redirect url so that i can redirect myself later
