v2.3.0
Docker
caddy run --config /etc/caddy/Caddyfile --adapter caddyfile --watch
build:
context: caddy-build/.
args:
- CADDY_VERSION=${CADDY_VERSION}
logging: *default-logging
restart: always
- proxy
DOMAINNAME: "${DOMAINNAME}"
- "80:80/tcp"
- "2019:2019"
command: ["caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile", "--watch"]
- "./certs:/certs" # file provider directory
- "./caddy/data:/data"
- "./caddy/Caddyfile:/etc/caddy/Caddyfile" # to mount custom Caddyfile
# auto_https off
localhost
header Authorization {system.os}:{scheme}:{tls_cipher}
respond "OK" 200
I would like to be able to base64 encode and decode values to be used in request headers (and other places). One example would be to get a username from a JWT cookie and from that create a basic auth header to then send to a downstream server. E.g.
oldhost.example.com {
route {
jwt
header Authorization "{http.auth.user.id}:mystaticpassword" # Need to base64 this value
reverse_proxy oldhost:80
If this functionality doesn’t exist I’m assuming I’d have to write a plugin (calling it alter, or mutate) that can encode/decode headers specifically, or maybe even placeholders?
Otherwise it might be a natural fit for https://github.com/caddyserver/caddy/blob/master/modules/caddyhttp/headers/headers.go
? However I think adding another option to encode/decode would break the existing config syntax?
A long shot, would it be possible to extend placeholders with Jinja-like filters? E.g. {http.auth.user.id | base64}
https://jinja.palletsprojects.com/en/2.11.x/templates/#filters
