WoJ
(WoJ)
March 16, 2017, 6:41am
1
Hello
This is my first attempt to run caddy (on Windows 10 x64).
I downloaded the .zip file, from which I extracted caddy.exe. When running it, it immediately shuts down with the following error message:
2017/03/16 07:36:19 The filename, directory name, or volume label syntax is incorrect.
What does that message mean? What is the filename, directory or volume label caddy is referring to?
Thank you for any help!
tobya
(Toby Allen)
March 16, 2017, 6:55am
2
This is a bug that has been fixed. For the moment you need to have a Caddyfile available in the same dir as the executable (I think even an empty Caddyfile will work)
https://github.com/mholt/caddy/pull/1431
WoJ
(WoJ)
March 16, 2017, 12:05pm
3
Thank you - yes, an empty Caddyfile works.
system
(system)
Closed
June 14, 2017, 12:12pm
4
