- Caddy version (
caddy version
Latest stable on Ubuntu Desktop 20.04. It should be v.2
- How I run Caddy:
Caddyfile configuration
Intel i5-8400T
32GB RAM
500GB NVME SSD
Jellyfin Media Server
Syncthing Media Server
sudo smartctl status caddy
sudo smartctl reload caddy
# domain name.
jellymmeirolas.ddnss.de {
reverse_proxy localhost:8096
syncmmeirolas.ddnss.de {
reverse_proxy localhost:8384 {
header_up Host localhost
# php_fastcgi localhost:9000
- The problem I’m having:
Using Kodi v19.0 in conjunction with the Jellyfin Kodi Addon, Kodi randomly crashes.
Sometimes it’s when watching a Video, but most of the times it’s right after the Jellyfin greetings message.
- Error messages and/or full log output:
â—Ź caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-05-07 17:17:39 CEST; 5h 19min ago
Main PID: 1620 (caddy)
Tasks: 12 (limit: 38074)
Memory: 39.2M
└─1620 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Mai 07 17:17:39 mmeiraserv caddy[1620]: {"level":"info","ts":1620400659.7911048,"logger":"tls","msg":"cleaned up storage units"}
Mai 07 17:17:39 mmeiraserv caddy[1620]: {"level":"info","ts":1620400659.7999945,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Mai 07 17:17:39 mmeiraserv caddy[1620]: {"level":"info","ts":1620400659.8000119,"msg":"serving initial configuration"}
Mai 07 21:46:58 mmeiraserv caddy[1620]: {"level":"error","ts":1620416818.3571558,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58156: >
Mai 07 21:47:12 mmeiraserv caddy[1620]: {"level":"error","ts":1620416832.0390239,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58160: >
Mai 07 21:48:05 mmeiraserv caddy[1620]: {"level":"error","ts":1620416885.494674,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58196: w>
Mai 07 21:48:05 mmeiraserv caddy[1620]: {"level":"error","ts":1620416885.5029018,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58200: >
Mai 07 21:56:51 mmeiraserv caddy[1620]: {"level":"error","ts":1620417411.2047021,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58474: >
Mai 07 21:56:51 mmeiraserv caddy[1620]: {"level":"error","ts":1620417411.2132554,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58472: >
Mai 07 21:57:08 mmeiraserv caddy[1620]: {"level":"error","ts":1620417428.4119852,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.178.23:443->5.10.50.141:58476: >
â—Ź jellyfin.service - Jellyfin Media Server
Loaded: loaded (/lib/systemd/system/jellyfin.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/jellyfin.service.d
└─jellyfin.service.conf
Active: active (running) since Fri 2021-05-07 17:17:34 CEST; 5h 16min ago
Main PID: 1006 (jellyfin)
Tasks: 29 (limit: 38074)
Memory: 7.9G
CGroup: /system.slice/jellyfin.service
└─1006 /usr/bin/jellyfin --webdir=/usr/share/jellyfin/web --restartpath=/usr/lib/jellyfin/restart.sh --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg
Mai 07 22:31:05 mmeiraserv jellyfin[1006]: [22:31:05] [WRN] WS 5.10.50.141 error receiving data: The remote party closed the WebSocket connection without completing the close handshake.
Mai 07 22:31:05 mmeiraserv jellyfin[1006]: [22:31:05] [INF] WS 5.10.50.141 closed
Mai 07 22:31:17 mmeiraserv jellyfin[1006]: [22:31:17] [INF] WS 5.10.50.141 request
Mai 07 22:31:18 mmeiraserv jellyfin[1006]: [22:31:18] [INF] Server Time Requested...
Mai 07 22:31:18 mmeiraserv jellyfin[1006]: [22:31:18] [INF] Sync Requested for UserID: 'e61f70dcdd75437793d45be9a9525c80' with LastUpdateDT: '2021-05-07T20:25:04z'
Mai 07 22:31:18 mmeiraserv jellyfin[1006]: [22:31:18] [INF] Added: 0, Removed: 0, Updated: 0, Changed User Data: 2
Mai 07 22:31:18 mmeiraserv jellyfin[1006]: [22:31:18] [INF] Request Finished Taking 00:00:00.0071901
Mai 07 22:32:05 mmeiraserv jellyfin[1006]: [22:32:05] [INF] Sending ForceKeepAlive message to 1 inactive WebSockets.
Mai 07 22:32:12 mmeiraserv jellyfin[1006]: [22:32:12] [WRN] WS 5.10.50.141 error receiving data: The remote party closed the WebSocket connection without completing the close handshake.
Mai 07 22:32:12 mmeiraserv jellyfin[1006]: [22:32:12] [INF] WS 5.10.50.141 closed
- What I already tried:
Reinstalling Kodi and the Jellyfin addon several times. Trying JellyCon instead of the Jellyfin addon.
Several settings within those addons.
Several settings inside Jellyfin Server itself.
Config Caddyfile in different ways.
Sorry, not ver versed in Linux to try much more.
