AWS S3 Bucket - Reverse Proxy
1. Output of caddy version:
Ubuntu 22.04
sudo systemctl start caddy
Service
Type=notify
# domain name.
    on_demand_tls {
        interval 10m
        burst 10
https:// {
        on_demand
    reverse_proxy {
        to http://bucketname.s3-website-us-east-1.amazonaws.com
*.example.com {
        dns route53 {
            access_key_id "AKIAzzzREPLACEME"
            secret_access_key "2GdiDzzzREPLACEME"
            max_retries 10
    reverse_proxy {
I have an S3 bucket configured as a static website, I can access it well through the URL provided by aws like as http://bucketname.s3-website-us-east-1.amazonaws.com or even through an address custom as app.example.com which is an “alias” on route53 for this bucket endpoint.
But when using Caddy as a reverse proxy for this target, I only get 404 NoSuchBucket error message.
If I change the target to any other site it works fine, but not for the bucket I need.
404 Not Found
Code: NoSuchBucket
Message: The specified bucket does not exist
BucketName: bucket_name
RequestId: T4BSHK2Dzzzzz
HostId: ZpAiCzdDvg3HVmE0ZRVdJ2Xzzzzzzzz=
Tried using lindenlab/caddy-s3-proxy plugin
1- Access website Download Caddy
2- Switch platform to Linux amd64
3- Select caddy-dns/route53 and lindenlab/caddy-s3-proxy plugins
4- Right click on the Download button and copy this address (something like https://caddyserver.com/api/download?os=windows&arch=amd64&p=github.com%2Fcaddy-dns%2Froute53&p=github. com%2Flindenlab%2Fcaddy-s3-proxy&idempotency=35019229369139)
5- SSH into Ubuntu and run the command:
sudo systemctl stop caddy
6- Run the command
sudo wget -O /usr/bin/caddy “https://caddyserver.com/api/download?os=windows&arch=amd64&p=github.com%2Fcaddy-dns%2Froute53&p=github.com%2Flindenlab%2Fcaddy-s3-proxy&idempotency =35019229369139”
But I always get the error:
Resolving caddyserver.com (caddyserver.com)… 165.227.20.207, 2604:a880:2:d0::21b0:6001
Connecting to caddyserver.com (caddyserver.com)|165.227.20.207|:443… connected.
HTTP request sent, awaiting response…
And then the caddy no longer starts returning that your bin is invalid.
If I just repeat the process selecting only the route53 plugin everything works fine (but then I don’t have the S3 plugin installed and so I get the 404 error)
Community Topics
Hi,
I managed to solve my problem, I share below what I did in case someone needs it too:
Note: I disregarded using the S3-proxy plugin, but I still use the Route53 plugin to generate wildcard certificates (this is reflected in my Caddyfile below).
1- I edited my Caddyfile from:
# domain name.
    on_demand_tls {
        interval 10m
        burst 10
https:// {
        on_demand
    reverse_proxy {
*.example.com {
        dns route53 {
            max_retries 10
    reverse_proxy {
2- To:
# domain name.
    on_demand_tls {
        interval 10m
        burst 10
https:// {
        on_demand
    reverse_proxy {
*.example.com {
        dns route53 {
            max_retries 10
    reverse_proxy {
So in summary, the “tip” was to add this line:
And after that my bucket no longer returned the 404 error and started working :slight_smile:
