I’m trying to deploy this github repository[1] to aws elasticbeanstalk, but for some reason the default configuration does not work in that environment while it does in my machine.
I suspect the reason is that meanwhile in my computer the connection is directly done against the caddy server using https, in aws I have a loadbalancer which is the one handling the https and then connecting to the caddy container using http. So what I should configure is something like CLIENT — HTTPS —> LOAD BALANCER — HTTP —> CADDY —> PHP.
How could I modify the Caddy configuration to work with the http protocol in this scenario?
Thank you for your time
Loops multiple times getting HTTP 308 response from caddy.
Docker
FROM caddy:2
Whatever does the official image to run the container
version: "3.4"
php:
build:
context: .
target: symfony_php
args:
SYMFONY_VERSION: ${SYMFONY_VERSION:-}
SKELETON: ${SKELETON:-symfony/skeleton}
STABILITY: ${STABILITY:-stable}
- php_socket:/var/run/php
healthcheck:
interval: 10s
timeout: 3s
retries: 3
start_period: 30s
build:
context: .
target: symfony_caddy
depends_on:
- php
SERVER_NAME: ${SERVER_NAME:-localhost, caddy:80}
- caddy_data:/data
- caddy_config:/config
# HTTP
- target: 80
published: ${HTTP_PORT:-80}
protocol: tcp
# HTTPS
- target: 443
published: ${HTTPS_PORT:-443}
protocol: tcp
# HTTP/3
- target: 443
published: ${HTTP3_PORT:-443}
protocol: udp
php_socket:
caddy_data:
caddy_config:
# Debug
{$DEBUG}
{$SERVER_NAME}
log
route {
root * /srv/app/public
mercure {
# Transport to use (default to Bolt)
transport_url {$MERCURE_TRANSPORT_URL:bolt:///data/mercure.db}
# Publisher JWT key
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
# Subscriber JWT key
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
# Allow anonymous subscribers (double-check that it's what you want)
anonymous
# Enable the subscription API (double-check that it's what you want)
subscriptions
# Extra directives
{$MERCURE_EXTRA_DIRECTIVES}
vulcain
push
php_fastcgi unix//var/run/php/php-fpm.sock
encode zstd gzip
[1] GitHub - mtarld/apip-ddd: An example of hexagonal API Platform 3 implementation · GitHub
