Automatically forward subdomain to port on localhost
v2.4.3
as a homebrew service on macOS with:
brew services start caddy
MacOS
/usr/local/opt/caddy/bin/caddy run --config /usr/local/etc/Caddyfile
This is the default homebrew.caddy.service installed by brew install caddy:
Description=Homebrew generated unit for caddy
Type=simple
ExecStart=/usr/local/opt/caddy/bin/caddy run --config /usr/local/etc/Caddyfile
Restart=always
StandardOutput=append:/usr/local/var/log/caddy.log
StandardError=append:/usr/local/var/log/caddy.log
3000.localhost {
    tls internal
    reverse_proxy localhost:3000
3001.localhost {
    tls internal
    reverse_proxy localhost:3001
3002.localhost {
    tls internal
    reverse_proxy localhost:3002
3020.localhost {
    tls internal
    reverse_proxy localhost:3020
4000.localhost {
    tls internal
    reverse_proxy localhost:4000
5000.localhost {
    tls internal
    reverse_proxy localhost:5000
6000.localhost {
    tls internal
    reverse_proxy localhost:6000
7000.localhost {
    tls internal
    reverse_proxy localhost:7000
8000.localhost {
    tls internal
    reverse_proxy localhost:8000
I’m working with a microservices architecture and often have to spin up multiple front-ends running on different ports, the above config is working for me but I have to add a new config section for each new service I start on a different port, this is starting to get messy.
It would be cool if I could instead configure caddy to capture the subdomain and reverse proxy automaticaly to that port on localhost but I can’t figure out a way to do this in the Caddyfile.
None
I’ve read through the docs but can’t figure out if what I’m trying is possble
Any help would be much appreciated.
Thanks
Rob
Maybe a snippet is what you’re after?
(sub2port) {
    {args.0}.localhost {
        tls internal
        reverse_proxy localhost:{args.0}
import sub2port 3000
import sub2port 3001
That does clean things up quite a bit thanks.
would be great to not have to list out all the ports though
Maybe something like this:
:443 {
	tls internal {
		on_demand
	@portLocalhost header_regexp port Host ^([0-9]+)\.localhost$
	handle @portLocalhost {
		reverse_proxy localhost:{re.port.1}
		respond "Bad hostname" 400
But a config like this would only be appropriate for development/local use. I cannot recommend this kind of pattern for production. Using on_demand opens you up for abuse unless you configure Caddy with the ask option to limit the domains for which certificates are issued.
This works perfectly thanks so much .
I get this is a very stupid thing to do in prod but it makes spinning up local servers with tls so easy, thanks again
