caddy:2.3.0-alpine
docker-compose -f docker-compose-caddy.yml up -d --build
paste command here
version: "3"
image: caddy:2.3.0-alpine
- $PWD/site:/srv
- caddy_data:/data
- caddy_config:/config
caddy_data:
caddy_config:
mono.mydomain.co {
on_demand
reverse_proxy 123.456.789.110:7050
I have created the following entries in Route53 (AWS)
mono.mydomain.co A 123.456.789.110
test.customerdomain.com CNAME mono.mydomain.co
Now, navigating to mono.mydomain.co
works fine and redirects to https
. What I also want is when someone navigates to test.customerdomain.com
it should also work with https
Instead, this is the error I see on the browser:
test.customerdomain.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
caddy_1 | {"level":"info","ts":1612388552.7430224,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1 | {"level":"info","ts":1612388552.7444458,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
caddy_1 | 2021/02/03 21:42:32 [INFO][cache:0xc0006e1c20] Started certificate maintenance routine
caddy_1 | {"level":"info","ts":1612388552.7465718,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy_1 | {"level":"info","ts":1612388552.749336,"logger":"tls","msg":"cleaned up storage units"}
caddy_1 | {"level":"info","ts":1612388552.7496638,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["mono.mydomain.co"]}
caddy_1 | {"level":"info","ts":1612388552.7499683,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
caddy_1 | {"level":"info","ts":1612388552.750061,"msg":"serving initial configuration"}
caddy_1 | 2021/02/03 21:42:50 http: TLS handshake error from 122.182.195.43:51484: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:42:50 http: TLS handshake error from 122.182.195.43:65133: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:42:56 http: TLS handshake error from 122.182.195.43:51486: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:42:56 http: TLS handshake error from 122.182.195.43:65135: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:33 http: TLS handshake error from 122.182.195.43:51494: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:33 http: TLS handshake error from 122.182.195.43:65143: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:33 http: TLS handshake error from 122.182.195.43:51496: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:34 http: TLS handshake error from 122.182.195.43:65145: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:42 http: TLS handshake error from 122.182.195.43:51498: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:42 http: TLS handshake error from 122.182.195.43:65147: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:49 http: TLS handshake error from 122.182.195.43:65149: no certificate available for 'test.customerdomain.com'
caddy_1 | 2021/02/03 21:44:49 http: TLS handshake error from 122.182.195.43:51502: no certificate available for 'test.customerdomain.com'
I am new to Caddy. In fact, this is my first Caddyfile. Please help me understand if this is even possible?
