2.5.1
docker-compose
Ubuntu 20.04, Docker 20.10.15, Compose 1.25.0
docker-compose up -d
version: "2.2"
container_name: caddy-cluster-proxy
image: caddy:2.5.1-alpine
- caddy_data:/data
- ./:/etc/caddy/
command: caddy run --config /etc/caddy/Caddyfile --watch
# Cached caddy data, e.g. certs
caddy_data:
import "*.Caddyfile"
https://159.223.140.9 {
Cache-Control "no-cache, no-store, must-revalidate"
handle_path /107731/* {
reverse_proxy http://159.223.140.9:8000 {
flush_interval -1
3. The problem Iâm having:
I want to enable HTTPS on just an IP address. When I use the above config I get HTTPS errors in my browser, and with curl:
curl https://159.223.140.9 -k -v
* Trying 159.223.140.9:443...
* Connected to 159.223.140.9 (159.223.140.9) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* TLSv1.2 (IN), TLS header, Unknown (21):
* error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection 0
curl: (35) error:0A000438:SSL routines::tlsv1 alert internal error
{"level":"info","ts":1657528686.1966174,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
{"level":"warn","ts":1657528686.19679,"msg":"No files matching import glob pattern","pattern":"*.Caddyfile"}
{"level":"warn","ts":1657528686.1981165,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":1}
{"level":"info","ts":1657528686.1991653,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1657528686.1993258,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1657528686.199342,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1657528686.1994512,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000217ab0"}
{"level":"info","ts":1657528686.200295,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1657528686.2009776,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1657528686.2203028,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
{"level":"debug","ts":1657528686.2206156,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
{"level":"debug","ts":1657528686.2206867,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1657528686.2207088,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["159.223.140.9"]}
{"level":"warn","ts":1657528686.2211394,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [159.223.140.9]: no OCSP server specified in certificate","identifiers":["159.223.140.9"]}
{"level":"debug","ts":1657528686.2211623,"logger":"tls.cache","msg":"added certificate to cache","subjects":["159.223.140.9"],"expiration":1657569657,"managed":true,"issuer_key":"local","hash":"9d440d4d2bbab98eeaf1e2a3ed669bbec7c347598f7f6a30bbffbc73b5ebc191","cache_size":1,"cache_capacity":10000}
{"level":"info","ts":1657528686.221428,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1657528686.2214453,"msg":"serving initial configuration"}
{"level":"info","ts":1657528686.2215388,"logger":"watcher","msg":"watching config file for changes","config_file":"/etc/caddy/Caddyfile"}
I believe HTTPS is technically possible with IP addresses: https - Is it possible to have SSL certificate for IP address, not domain name? - Stack Overflow
And I think Caddy uses ZeroSSL, which supports certs for IP addresses: https://help.zerossl.com/hc/en-us/articles/360060119973-Is-It-Possible-To-Generate-a-SSL-Certificate-for-an-IP-Address-
But Iâve only seen cert errors when I use this setup.
(Why am I doing this? We spin up/down servers every day on a schedule with terraform. Getting DNS to work with this system would be a pain. Currently we have a few small permanent servers that I run Caddy on it with a regular domain name that reverse proxies to our Terraform servers, but Iâm trying to remove this server-for-the-sake-of-a-domain-name).
