v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
Debian 11.
/usr/bin/caddy run --config /etc/caddy/caddy-config.json
not applicable.
"apps": {
"http": {
"servers": {
"app_name_here": {
"automatic_https": {
"disable_certificates": true
"listen": [
":80",
":443"
"routes": [
"handle": [
"body": "yo bruh, this worky!",
"handler": "static_response"
"match": [
"host": [
"domain.example.net"
"tls_connection_policies": [
"match": {
"sni": [
"tls": {
"certificates": {
"load_files": [
"certificate": "/etc/caddy/certificates/star.example.com.bundle",
"key": "/etc/caddy/certificates/star.example.com.privkey"
"certificate": "/etc/caddy/certificates/star.example.net.bundle",
"key": "/etc/caddy/certificates/star.example.net.privkey"
I expect the port 80 to redirect to 443 because I set disable_certificates
to true
, which should only disable automatic generation, but not the redirect.
2022/06/23 13:09:49.454 INFO using provided configuration {"config_file": "/etc/caddy/caddy-config.json", "config_adapter": ""}
2022/06/23 13:09:49.456 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/06/23 13:09:49.457 WARN http skipping automated certificate management for server because it is disabled{"server_name": "app_name_here"}
2022/06/23 13:09:49.457 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "app_name_here"}
2022/06/23 13:09:49.457 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2022/06/23 13:09:49.457 INFO serving initial configuration
2022/06/23 13:09:49.457 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000445260"}
2022/06/23 13:09:49.457 INFO tls cleaning storage unit {"description": "FileStorage:/root/.local/share/caddy"}
2022/06/23 13:09:49.458 INFO tls finished cleaning storage units
Running with automatic HTTPS via example Caddyfile, where the redirect works. Automatic HTTPS redirect doesn’t work with custom certificate
Somehow my setup only works when using automatic mode. I’d appreciate any help. What can I do besides creating a route for every HTTP → HTTPS redirection? I’d like to keep the config as minimal as possible. Automatic HTTPS redirect doesn’t work with custom certificate
