Automatic http -> https logger
The problem I’m having:
I have a domain block without a protocol prefix, so Caddy automatically sets up http → https redirecting. I have a log directive for this domain also. But logs generated by the http server do not end up in this log file (but rather in journald). Only the logs generated by the https server end up in this log file. How can I specify the log file for the http server, or alternatively, how can I turn those off? Do I need to explicitly configure a http and https block for the same domain and setup redirecting myself if I also want to configure the log directive?
Those are probably not access logs, those are process logs.
Just do this:
http:// {
Why do you want logs for the redirects though? Pretty useless, no?
Please fill out the entire topic template, without the rest filled in we’re missing important context for your question (e.g. your config, existing logs, Caddy version, how you’re running Caddy) which would let me answer more precisely.
No they are definitely access logs.. (unless "logger":"http.log.access" qualifies as a process log?)
Feb 23 10:26:53 polyestershoppen caddy[1185088]: {"level":"info","ts":1771838813.4650223,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"66.249.72.137","remote_port":"55187","client_ip":"66.249.72.137","proto":"HTTP/1.1","method":"GET","host":"polyestershoppen.nl","uri":"/robots.txt","headers":{"Accept":["text/plain,text/html,*/*"],"User-Agent":["Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"],"Accept-Encoding":["gzip, deflate, br"],"Connection":["keep-alive"]}},"bytes_read":0,"user_id":"","duration":0.000026884,"size":0,"status":308,"resp_headers":{"Content-Type":[],"Server":["Caddy"],"Connection":["close"],"Location":["https://polyestershoppen.nl/robots.txt"]}}
Feb 23 10:26:53 polyestershoppen caddy[1185088]: {"level":"info","ts":1771838813.5729022,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"66.249.77.131","remote_port":"41433","client_ip":"66.249.77.131","proto":"HTTP/1.1","method":"GET","host":"polyestershoppen.fr","uri":"/robots.txt","headers":{"Connection":["keep-alive"],"Accept":["text/plain,text/html,*/*"],"User-Agent":["Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"],"Accept-Encoding":["gzip, deflate, br"]}},"bytes_read":0,"user_id":"","duration":0.000031826,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://polyestershoppen.fr/robots.txt"],"Content-Type":[]}}
Feb 23 10:26:53 polyestershoppen caddy[1185088]: {"level":"info","ts":1771838813.8293443,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"66.249.77.131","remote_port":"52735","client_ip":"66.249.77.131","proto":"HTTP/1.1","method":"GET","host":"polyestershoppen.fr","uri":"/ads.txt","headers":{"Accept-Encoding":["gzip, deflate, br"],"Connection":["keep-alive"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"From":["googlebot(at)googlebot.com"],"User-Agent":["Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"]}},"bytes_read":0,"user_id":"","duration":0.000033708,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https://polyestershoppen.fr/ads.txt"],"Content-Type":[]}}
Here is our Caddy config
  # https://caddyserver.com/docs/caddyfile/options#email
  email development@polyestershoppen.nl
  # https://caddyserver.com/docs/caddyfile/options#order
  order abort before handle
  servers {
    trusted_proxies static private_ranges
  preferred_chains {
    root_common_name "DST Root CA X3"
(whitelist) {
  @whitelist {
      remote_ip 81.173.61.72 # Polyestershoppen Moordrecht
      remote_ip 77.172.127.71 # Sjoerd thuis
      remote_ip 86.80.105.251 # Herman thuis
      remote_ip 77.169.50.35 # Rob thuis
      remote_ip 84.84.178.72 # Kees thuis
      remote_ip 77.161.77.233 # Wendy Goodman thuis
      remote_ip 78.197.22.33 # Jerome thuis
      remote_ip 81.204.76.106 # Scrumble kantoor
      remote_ip 185.100.131.140 # Scrumble server
      remote_ip 89.19.60.120 # Erocket
      # all private IPv4 and IPv6 ranges
      remote_ip private_ranges
(blacklist) {
  @blacklist {
    not {
:8080 {
  root * /srv/polyestershoppen.nl/web
  encode zstd gzip
  header -server
  header +via "Caddy Production Backend"
  header >x-request-id {http.request.header.x-request-id}
  php_fastcgi unix//run/php/php-fpm.sock {
    resolve_root_symlink
    env APP_ENV prod
    try_files /app.php{path}
    output file /var/log/caddy/backend.log {
      roll_disabled # use logrotate.d
    format json
:8081 {
  root * /srv/development.polyestershoppen.nl/web
  encode zstd gzip
  header -server
  header +via "Caddy Development Backend"
    env APP_ENV uat
    format json
fpm.polyestershoppen.nl {
  import blacklist
  abort @blacklist
  reverse_proxy / unix//run/php/php-fpm-status.sock {
    transport fastcgi {
      env SCRIPT_NAME /status
    output file /var/log/caddy/fpm.log {
    format json
http://www.polyestershoppen.nl, https://www.polyestershoppen.nl {
  redir https://polyestershoppen.nl{uri} 301
http://www.polyestershoppen.fr, https://www.polyestershoppen.fr {
  redir https://polyestershoppen.fr{uri} 301
http://www.polyestershoppen.be, https://www.polyestershoppen.be {
  redir https://polyestershoppen.be{uri} 301
http://www.polyestershoppen.com, https://www.polyestershoppen.com {
  redir https://polyestershoppen.com{uri} 301
  encode zstd gzip
  import blacklist
  header -server
  header >via "Caddy Frontend Proxy"
  header @blacklist {
    -via
    -x-varnish
    -x-powered-by
    -x-varnish-*
    -x-debug-*
  # CORS header defaults (allows backend headers to take precedence)
  # https://developer.mozilla.org/en-US/docs/Web/HTTP/CORS
  header ?access-control-allow-origin *
  header ?access-control-allow-methods "OPTIONS, GET, POST, PUT, PATCH, DELETE"
  header ?access-control-allow-headers *
  header ?access-control-expose-headers *
  # https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/X-Content-Type-Options
  header ?x-content-type-options nosniff
  # https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/X-Frame-Options
  header ?x-frame-options DENY
  # https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Referrer-Policy
  header ?referrer-policy "same-origin, strict-origin-when-cross-origin"
  @phpfile path *.php *.php/*
  @exists file
  @static path *.jpg *.jpeg *.js *.css *.png *.woff *.woff2 *.otf *.ttf *.gif *.svg *.webp
  handle @phpfile {
    error 403
  handle /openapi/* {
    basic_auth @blacklist {
      polyestershoppen yadayada
  handle @exists {
    header @static ?cache-control "public, max-age=604800, s-maxage=86400, stale-while-revalidate=3600, must-revalidate"
  @noproxy path /actievoorwaarden/* /algemenevoorwaarden/* /amazon/* /assets/* /build/* /images/* /img/*
  handle @noproxy {
    try_files {path} =404
  @skipvarnish path /admin/* /api/*
  handle @skipvarnish {
    reverse_proxy {
      to http://localhost:8080
      header_up x-real-ip {remote_host}
      header_up x-request-id {http.request.uuid}
        dial_timeout 2s
        keepalive 60s
    reverse_proxy {
      to http://10.110.0.3:6081
        dial_timeout 2s
        keepalive 60s
    output file /var/log/caddy/proxy.log {
    format json
http://development.polyestershoppen.nl {
  redir https://development.polyestershoppen.nl{uri} 301
http://development.polyestershoppen.fr {
  redir https://development.polyestershoppen.fr{uri} 301
http://development.polyestershoppen.be {
  redir https://development.polyestershoppen.be{uri} 301
http://development.polyestershoppen.com {
  redir https://development.polyestershoppen.com{uri} 301
development.polyestershoppen.nl,
development.polyestershoppen.be,
development.polyestershoppen.fr,
  encode zstd gzip
  import blacklist
  header -server
  header +via "Caddy Development Proxy"
  @exists file
  handle @phpfile {
    error 403
  handle @exists {
  handle @noproxy {
      env APP_ENV uat
    output file /var/log/caddy/development.log {
    format json
http://poetsenpolijsten.nl,
http://www.poetsenpolijsten.nl,
https://poetsenpolijsten.nl,
https://www.poetsenpolijsten.nl {
  # specific paths
  redir /auto-poetsset-polijstset-reinigingset/* https://polyestershoppen.nl/polijsten permanent
  redir /bevestigingssysteem/klittenbandvelcro/* https://polyestershoppen.nl/schuren-en-polijsten permanent
  redir /category/informatiecentrum/* https://polyestershoppen.nl/info/ permanent
  redir /doffe-plekken-autolak-herstellen-verwijderen/* https://polyestershoppen.nl/info/doffe-autolak-herstellen-hoe-doe-je-dat permanent
  redir /farecla-producten/* https://polyestershoppen.nl/farecla permanent
  redir /informatiecentrum/stappenplan/* https://polyestershoppen.nl/info/farecla-g3-pro-car-detailing-in-3-eenvoudige-stappen permanent
  redir /informatiecentrum/wat-is-carnaubawax/* https://polyestershoppen.nl/info/carnaubawas-de-perfecte-bescherming-voor-jouw-auto permanent
  redir /informatiecentrum/wat-is-excentrisch-roterend-polijsten/* https://polyestershoppen.nl/info/alles-wat-je-moet-weten-over-polijsten-roterend-vs-dual-action permanent
  redir /informatiecentrum/wat-is-roterend-polijsten/* https://polyestershoppen.nl/info/alles-wat-je-moet-weten-over-polijsten-roterend-vs-dual-action permanent
  redir /klantenservice/betaalmethodes/* https://polyestershoppen.nl/klantenservice/betalen permanent
  redir /klantenservice/betaalmogelijkheden/* https://polyestershoppen.nl/klantenservice/betalen permanent
  redir /klantenservice/contact/* https://polyestershoppen.nl/contact permanent
  redir /klantenservice/over-poetsenpolijsten-nl/* https://polyestershoppen.nl/over-ons permanent
  redir /klantenservice/retourneren/* https://polyestershoppen.nl/returnorder permanent
  redir /klantenservice/verzending-en-bezorging/* https://polyestershoppen.nl/klantenservice/bestellen-en-leveren permanent
  redir /klantenservice/waarom-kopen-bij-poetsenpolijsten-nl/* https://polyestershoppen.nl/over-ons permanent
  redir /korrelgrofte/p3000/* https://polyestershoppen.nl/schuren-en-polijsten permanent
  redir /merk/biltec/* https://polyestershoppen.nl/merken/biltec permanent
  redir /mijn-account/* https://polyestershoppen.nl/mijn-account permanent
  redir /polyester-paardentrailer-poetsen/* https://polyestershoppen.nl/info/paardentrailer-poetsen-en-polijsten-stap-voor-stap-handleiding permanent
  redir /product-categorie/auto-poetsen/* https://polyestershoppen.nl/reinigen permanent
  redir /product-categorie/camper-caravan-poetsen-polijsten/caravan-reinigingsmiddelen/* https://polyestershoppen.nl/reinigen permanent
  redir /product-categorie/camper-caravan-poetsen-polijsten/caravan-schuurmiddelen/* https://polyestershoppen.nl/schuren-en-polijsten permanent
  redir /product-categorie/camper-caravan-poetsen-polijsten/* https://polyestershoppen.nl/polijsten permanent
  redir /product-categorie/jacht-boot-poetsen-polijsten/boot-reinigingsmiddelen/* https://polyestershoppen.nl/reinigen permanent
  redir /product-categorie/jacht-boot-poetsen-polijsten/* https://polyestershoppen.nl/polijsten permanent
  redir /product-categorie/merken/3m/* https://polyestershoppen.nl/merken/3m permanent
  redir /product-categorie/merken/autoglym/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/commandant/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/dulon/* https://polyestershoppen.nl/merken/dulon permanent
  redir /product-categorie/merken/farecla/* https://polyestershoppen.nl/merken/farecla permanent
  redir /product-categorie/merken/gloria/gloria-brushsystems-roterende-onkruidborstels-oppervlakteborstels/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/gloria/gloria-drukspuiten/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/imbema-rhiwa/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/impro/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/kranzle/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/martin-cox-chamois/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/milwaukee/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/mirka/mirka-abranet/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abranet-ace-150mm-per-5-vel-1127.html permanent
  redir /product-categorie/merken/mirka/mirka-deros/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deros-150mm-schuurmachine-575.html permanent
  redir /product-categorie/merken/mirka/* https://polyestershoppen.nl/merken/mirka permanent
  redir /product-categorie/merken/riwax/* https://polyestershoppen.nl/merken/riwax permanent
  redir /product-categorie/merken/rupes/* https://polyestershoppen.nl/merken/rupes permanent
  redir /product-categorie/merken/sonax/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/turtle-wax/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/merken/* https://polyestershoppen.nl/merken permanent
  redir /product-categorie/nieuw-in-het-assortiment/* https://polyestershoppen.nl/ permanent
  redir /product-categorie/poets-en-polijsten/* https://polyestershoppen.nl/polijsten permanent
  redir /product-categorie/reinigen/* https://polyestershoppen.nl/reinigen permanent
  redir /product-categorie/schuren/schuurmachines/schuurmachine-77mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deros-77mm-schuurmachine-1340.html permanent
  redir /product-categorie/schuren/* https://polyestershoppen.nl/schuren-en-polijsten permanent
  redir /product-categorie/uitverkoop/* https://polyestershoppen.nl/koopjeshoek permanent
  redir /product-categorie/voordeelsets/* https://polyestershoppen.nl/ permanent
  redir /product/2-0-liter-black-foaming-sprayer/* https://polyestershoppen.nl/reinigen/foaming-sprayer-2l-1866.html permanent
  redir /product/4dry-multi-ontvochtiger-voor-kleine-ruimtes-05kg/* https://polyestershoppen.nl/bootonderhoud/4dry-multi-ontvochtiger-voor-kleine-ruimtes-1101.html permanent
  redir /product/bandenspons-groen-zwart/* https://polyestershoppen.nl/reinigen/bandenspons-groen-zwart-1867.html permanent
  redir /product/black-diamond-airco-reiniger/* https://polyestershoppen.nl/reinigen/black-diamond-airco-reiniger-1965.html permanent
  redir /product/black-diamond-glass-cleaner-5liter/* https://polyestershoppen.nl/reinigen/black-diamond-glass-cleaner-1966.html permanent
  redir /product/black-diamond-leerreiniger/* https://polyestershoppen.nl/reinigen/black-diamond-leerreiniger-1974.html permanent
  redir /product/black-diamond-rapid-glass-cleaner/* https://polyestershoppen.nl/reinigen/black-diamond-glass-cleaner-1966.html permanent
  redir /product/black-diamond-trim-gel/* https://polyestershoppen.nl/reinigen/black-diamond-trim-gel-1976.html permanent
  redir /product/borstel-voor-dierenharen/* https://polyestershoppen.nl/reinigen/borstel-voor-dierenharen-1837.html permanent
  redir /product/bug-shifter-spons-insecetenspons/* https://polyestershoppen.nl/reinigen/martin-cox-insectenspons-1928.html permanent
  redir /product/emmer-20-liter/* https://polyestershoppen.nl/reinigen/martin-cox-wasemmer-20-liter-1953.html permanent
  redir /product/extra-zachte-microvezel-washandschoen/* https://polyestershoppen.nl/reinigen/extra-zachte-washandschoen-1870.html permanent
  redir /product/farecla-1-2-g3-voordeelset/* https://polyestershoppen.nl/farecla/farecla-1-2-g3-polijstpakket-1862.html permanent
  redir /product/farecla-clean-protect-spray/* https://polyestershoppen.nl/schuren-en-polijsten/farecla-clean-and-protect-spray-1561.html permanent
  redir /product/farecla-dual-action-polijst-set/* https://polyestershoppen.nl/farecla/farecla-g-plus-dual-action-polijsten-pakket-1753.html permanent
  redir /product/gloria-cleanmaster-cm10-zuurbestendige-handsproeier-1-liter/* https://polyestershoppen.nl//reinigen/gloria-cleanmaster-cm10-1833.html permanent
  redir /product/gloria-cleanmaster-cm12-hand-druksproeier-1-liter/* https://polyestershoppen.nl/reinigen/gloria-cleanmaster-cm12-1836.html permanent
  redir /product/gloria-cleanmaster-cm50-drukspuit-5-liter/* https://polyestershoppen.nl/reinigen/gloria-cleanmaster-cm50-1853.html permanent
  redir /product/gloria-cleanmaster-extreme-ex10-handsproeier-1-liter/* https://polyestershoppen.nl/reinigen/gloria-cleanmaster-extreme-ex10-1940.html permanent
  redir /product/gloria-cleanmaster-extreme-ex100-hand-druksproeier-1-liter/* https://polyestershoppen.nl/reinigen/gloria-cleanmaster-extreme-ex100-1941.html permanent
  redir /product/gloria-cleanmaster-performance-pf50-drukspuit-5-liter/* https://polyestershoppen.nl/reinigen/gloria-cleanmaster-performance-pf50-1942.html permanent
  redir /product/gloria-drukspuit-autopump-easy-spray-5-liter/* https://polyestershoppen.nl/reinigen/gloria-autopump-1944.html permanent
  redir /product/gloria-fm50-foammaster-druksproeier-5liter/* https://polyestershoppen.nl/reinigen/gloria-foammaster-fm50-1855.html permanent
  redir /product/gloria-foammaster-fm10-druksproeier/* https://polyestershoppen.nl/reinigen/gloria-foammaster-fm10-1liter-1835.html permanent
  redir /product/gloria-prima-5-42e-drukspuit-5-liter/* https://polyestershoppen.nl/reinigen/gloria-prima-5-1943.html permanent
  redir /product/handpad-soft-waffle/* https://polyestershoppen.nl/polijsten/handpad-soft-waffle-1860.html permanent
  redir /product/handpad-soft/* https://polyestershoppen.nl/polijsten/handpad-soft-1861.html permanent
  redir /product/handpalmschuurmachine-mirka-deros-680cv-150mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deros-150mm-schuurmachine-575.html permanent
  redir /product/heavy-duty-emmer-15l/* https://polyestershoppen.nl/reinigen/martin-cox-heavy-duty-wasemmer-15-liter-1954.html permanent
  redir /product/ik-foam-pro-2/* https://polyestershoppen.nl/reinigen/ik-foam-pro-2-1854.html permanent
  redir /product/luchtontvochtiger-auto/* https://polyestershoppen.nl/bootonderhoud/4dry-cars-ontvochtiger-voor-boten-1100.html permanent
  redir /product/martin-cox-american-car-duster/* https://polyestershoppen.nl/reinigen/martin-cox-stofborstel-1934.html permanent
  redir /product/martin-cox-applicator-poetspad/* https://polyestershoppen.nl/polijsten/martin-cox-applicator-pad-zacht-120-mm-1930.html permanent
  redir /product/martin-cox-auto-bekleding-reiniging-borstel/* https://polyestershoppen.nl/reinigen/martin-cox-interieur-borstel-1886.html permanent
  redir /product/martin-cox-auto-luchtverfrisser-bubblegum-original/* https://polyestershoppen.nl/reinigen/martin-cox-auto-luchtverfrisser-1929.html permanent
  redir /product/martin-cox-auto-luchtverfrisser-mountain-air/* https://polyestershoppen.nl/reinigen/martin-cox-auto-luchtverfrisser-1929.html permanent
  redir /product/martin-cox-auto-luchtverfrisser-neutra-d/* https://polyestershoppen.nl/reinigen/martin-cox-auto-luchtverfrisser-1929.html permanent
  redir /product/martin-cox-auto-luchtverfrisser-new-car-scent/* https://polyestershoppen.nl/reinigen/martin-cox-auto-luchtverfrisser-1929.html permanent
  redir /product/martin-cox-auto-luchtverfrisser-sunburst/* https://polyestershoppen.nl/reinigen/martin-cox-auto-luchtverfrisser-1929.html permanent
  redir /product/martin-cox-borstel-dierenharen-verwijderen/* https://polyestershoppen.nl/reinigen/borstel-voor-dierenharen-1939.html permanent
  redir /product/martin-cox-borstel-wateraansluiting/* https://polyestershoppen.nl/reinigen/wasborstel-met-wateraansluiting-1921.html permanent
  redir /product/martin-cox-clay-bar-medium-100-gram/* https://polyestershoppen.nl/reinigen/martin-cox-clay-bar-medium-1888.html permanent
  redir /product/martin-cox-clay-mitt-klei-handschoen-fine/* https://polyestershoppen.nl/reinigen/kleihandschoen-fine-1889.html permanent
  redir /product/martin-cox-clay-mitt-klei-handschoen-medium/* https://polyestershoppen.nl/reinigen/kleihandschoen-medium-1890.html permanent
  redir /product/martin-cox-conische-wielborstel-22cm/* https://polyestershoppen.nl/reinigen/conische-velgenborstel-1877.html permanent
  redir /product/martin-cox-detailling-towel-40x40cm/* https://polyestershoppen.nl/reinigen/martin-cox-microvezel-detailing-towel-1931.html permanent
  redir /product/martin-cox-grill-en-velgenborstel/* https://polyestershoppen.nl/reinigen/standaard-velgenborstel-1881.html permanent
  redir /product/martin-cox-gritt-guard/* https://polyestershoppen.nl/reinigen/martin-cox-grit-guard-1882.html permanent
  redir /product/martin-cox-hydra-flexi-wisser/* https://polyestershoppen.nl/reinigen/martin-cox-hydra-flexi-wisser-1927.html permanent
  redir /product/martin-cox-kleidoek-fine-30x30cm/* https://polyestershoppen.nl/reinigen/kleidoek-fine-30x30cm-1875.html permanent
  redir /product/martin-cox-kleidoek-medium-30x30cm/* https://polyestershoppen.nl/reinigen/kleidoek-medium-30x30cm-1874.html permanent
  redir /product/martin-cox-luchtverfrisser-ice-bold-scent/* https://polyestershoppen.nl/reinigen/martin-cox-auto-luchtverfrisser-1929.html permanent
  redir /product/martin-cox-microvezel-detailing-doek-towel-50-x-80-cm/* https://polyestershoppen.nl/reinigen/martin-cox-microvezel-detailing-towel-1931.html permanent
  redir /product/martin-cox-microvezel-droogdoek-60-80-cm/* https://polyestershoppen.nl/reinigen/gewafelde-microvezel-droogdoek-1872.html permanent
  redir /product/martin-cox-microvezel-extra-grote-droogdoek-101-x-63-cm/* https://polyestershoppen.nl/reinigen/martin-cox-droogdoek-1856.html permanent
  redir /product/martin-cox-microvezel-flexibele-wielborstel/* https://polyestershoppen.nl/reinigen/flexibele-velgenborstel-1876.html permanent
  redir /product/martin-cox-microvezel-glasdoek-zijde/* https://polyestershoppen.nl/reinigen/microvezel-glasdoek-40x40cm-1873.html permanent
  redir /product/martin-cox-microvezel-wielborstel-2-in-1/* https://polyestershoppen.nl/reinigen/2-in1-microvezel-velgenborstel-1878.html permanent
  redir /product/martin-cox-microvezeldoek-polijstdoek-40x40cm/* https://polyestershoppen.nl/polijsten/martin-cox-microvezel-polijstdoek-40x40cm-1850.html permanent
  redir /product/martin-cox-spons-17x12x5cm/* https://polyestershoppen.nl/reinigen/martin-cox-spons-18x12x5-cm-1891.html permanent
  redir /product/martin-cox-telescoopsteel-3meter/* https://polyestershoppen.nl/reinigen/telescoopsteel-3-meter-1851.html permanent
  redir /product/martin-cox-telescoopsteel-uitschuifbaar-3meter-uitschuifbaar/* https://polyestershoppen.nl/reinigen/telescoopsteel-3-meter-1851.html permanent
  redir /product/martin-cox-vernevelaar-05-liter https://polyestershoppen.nl/reinigen/martin-cox-vernevelaar-0-5l-1958.html permanent
  redir /product/martin-cox-washandschoen-2-in-1/* https://polyestershoppen.nl/reinigen/2-in-1-washandschoen-1920.html permanent
  redir /product/martin-cox-washandschoen-dreads-geel/* https://polyestershoppen.nl/reinigen/martin-cox-washandschoen-1869.html permanent
  redir /product/martin-cox-washandschoen-dreads-oranje/* https://polyestershoppen.nl/reinigen/martin-cox-washandschoen-1869.html permanent
  redir /product/martin-cox-washandschoen-met-dreads-wiggly-mitt-groen/* https://polyestershoppen.nl/reinigen/martin-cox-washandschoen-1869.html permanent
  redir /product/martin-cox-washandschoen-schapenvacht/* https://polyestershoppen.nl/reinigen/martin-cox-schapenvacht-washandschoen-1919.html permanent
  redir /product/martin-cox-wielborstel-zacht/* https://polyestershoppen.nl/reinigen/martin-cox-borstel-voor-lichtmetalen-velgen-1938.html permanent
  redir /product/martin-cox-zeem-synthetisch-gemsleer/* https://polyestershoppen.nl/reinigen/martin-cox-pva-droogzeem-1926.html permanent
  redir /product/mirka-abralon-handschuurpads-115x140mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abralon-handvel-450.html permanent
  redir /product/mirka-abralon-schuurschijven-150mm-2stuks/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abralon-150mm-matteerschijven-373.html permanent
  redir /product/mirka-abralon-schuurschijven-77mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abralon-77mm-447.html permanent
  redir /product/mirka-abranet-schuurschijven-125mm-10stuks/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abranet-ace-125mm-per-5-vel-903.html permanent
  redir /product/mirka-abranet-schuurschijven-125mm-50stuks/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abranet-ace-125mm-per-doos-524.html permanent
  redir /product/mirka-abranet-schuurschijven-150mm-10stuks/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abranet-ace-150mm-per-5-vel-1127.html permanent
  redir /product/mirka-abranet-schuurschijven-150mm-50stuks/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abranet-150mm-schuurgaas-per-doos-566.html permanent
  redir /product/mirka-abranet-schuurschijven-77mm-50stuks/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-abranet-77mm-per-doos-1270.html permanent
  redir /product/mirka-beschermpad-125mm-33-gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-padsaver-902.html permanent
  redir /product/mirka-beschermpad-125mm-44-gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-padsaver-902.html permanent
  redir /product/mirka-beschermpad-77mm-6gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-padsaver-902.html permanent
  redir /product/mirka-beschermpad-abranet-padsaver-150mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-padsaver-902.html permanent
  redir /product/mirka-deos-353cv-81x133mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deos-353cv-vlakschuurmachine-81x133mm-1337.html permanent
  redir /product/mirka-deos-383cv-70x198mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deos-383cv-vlakschuurmachine-70x198mm-1338.html permanent
  redir /product/mirka-deos-663cv-delta/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deos-663cv-delta-schuurmachine-820.html permanent
  redir /product/mirka-deros-625cv-150mm-elektrische-schuurmachine/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deros-150mm-schuurmachine-575.html permanent
  redir /product/mirka-deros-650-steunschijf-125mm-28-gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-steunschijf-125mm-1899.html permanent
  redir /product/mirka-deros-650cv-150mm-bluetooth-my-mirka/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deros-150mm-schuurmachine-575.html permanent
  redir /product/mirka-deros-650cv-in-systainer/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-deros-in-systainer-1111.html permanent
  redir /product/mirka-deros-combislang-10-meter/* https://polyestershoppen.nl/schuren-en-polijsten/combislang-voor-mirka-deros-1032.html permanent
  redir /product/mirka-deros-combislang-4-meter-230v/* https://polyestershoppen.nl/schuren-en-polijsten/combislang-voor-mirka-deros-1032.html permanent
  redir /product/mirka-deros-combislang-5-meter/* https://polyestershoppen.nl/schuren-en-polijsten/combislang-voor-mirka-deros-1032.html permanent
  redir /product/mirka-deros-stroomkabel-10-meter/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stroomkabel-230v-1902.html permanent
  redir /product/mirka-deros-stroomkabel-4-meter/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stroomkabel-230v-1902.html permanent
  redir /product/mirka-flexibel-handschuurblok/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-flexibel-schuurblok-1955.html permanent
  redir /product/mirka-glas-polijstset-125mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-glas-polijstset-1829.html permanent
  redir /product/mirka-glas-polijstset-polijsten-schuren/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-glas-polijstset-1829.html permanent
  redir /product/mirka-gold-delta-per-5-stuks/* https://polyestershoppen.nl/schuren-en-polijsten/schuurschijf-delta-mirka-gold-per-5-stuks-560.html permanent
  redir /product/mirka-gold-delta-per-doos/* https://polyestershoppen.nl/schuren-en-polijsten/schuurschijf-delta-mirka-gold-per-doos-562.html permanent
  redir /product/mirka-gold-schuurschijven-125mm-15-gaten/* https://polyestershoppen.nl/schuren-en-polijsten/schuurschijf-150mm-korrel-40-800-241.html permanent
  redir /product/mirka-gold-schuurschijven-150mm-17gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-gold-schuurschijf-125mm-per-5-stuks-848.html permanent
  redir /product/mirka-gold-schuurschijven-77mm/* https://polyestershoppen.nl/koopjeshoek/mirka-gold-schuurschijf-77-mm-per-10-stuks-1813.html permanent
  redir /product/mirka-gold-schuurschijven-77mm/* https://polyestershoppen.nl/koopjeshoek/mirka-microstar-77-mm-per-10-stuks-1814.html permanent
  redir /product/mirka-gold-schuurschijven-o125mm-per-5st-kopie/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-gold-125mm-per-doos-892.html permanent
  redir /product/mirka-gold-schuurschijven-o150mm-per-doos/* https://polyestershoppen.nl/schuren-en-polijsten/schuurschijf-150mm-per-doos-242.html permanent
  redir /product/mirka-handpad-handblok-150mm-velcro/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-handschuurzool-150-mm-1846.html permanent
  redir /product/mirka-handschuurblok-150mm-handvorm/* https://polyestershoppen.nl/schuren-en-polijsten/schuurmuis-150mm-555.html permanent
  redir /product/mirka-handschuurblok-donut-77mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-handschuurblok-ergo-77-mm-1847.html permanent
  redir /product/mirka-industriele-schuurstofzuiger-1230-l-auto-filter-cleaning/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stofzuiger-1230-l-automatic-filter-cl-1905.html permanent
  redir /product/mirka-koffer-voor-ceros-deros/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-systainers-opbergkoffer-1908.html permanent
  redir /product/mirka-microstar-schuurschijven-150mm-15gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-microstar-150mm-per-doos-1129.html permanent
  redir /product/mirka-polarshine-10-medium-grof-polijstmiddel-finish/* https://polyestershoppen.nl/polijsten/mirka-polarshine-10-medium-polish-finish-1838.html permanent
  redir /product/mirka-polarshine-15-medium-polijstmiddel/* https://polyestershoppen.nl/polijsten/mirka-polarshine-15-medium-polijstmiddel-1840.html permanent
  redir /product/mirka-polarshine-20-medium-grof-polijstmiddel-1-liter/* https://polyestershoppen.nl/polijsten/mirka-polarshine-20-medium-grof-polijstmiddel-1841.html permanent
  redir /product/mirka-polarshine-25-gelcoat-polijstmiddel-1liter/* https://polyestershoppen.nl/polijsten/mirka-polarshine-25-polijstmiddel-voor-gelcoat-1842.html permanent
  redir /product/mirka-polarshine-3-wax-fijn-poetsmiddel/* https://polyestershoppen.nl/polijsten/mirka-polarshine-3-wax-finish-1831.html permanent
  redir /product/mirka-polarshine-35-zeer-grof-polijstmiddel/* https://polyestershoppen.nl/polijsten/mirka-polarshine-35-zeer-grof-polijstmiddel-1832.html permanent
  redir /product/mirka-polarshine-5-finish-polijstmiddel-250ml/* https://polyestershoppen.nl/polijsten/mirka-polarshine-5-afwerkingcompound-1834.html permanent
  redir /product/mirka-polarshine-5-finishing-polijstmiddel-1-liter/* https://polyestershoppen.nl/polijsten/mirka-polarshine-5-afwerkingcompound-1834.html permanent
  redir /product/mirka-polarshine-e3-glas-polijstmiddel-1-liter/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-polarshine-e3-glas-polijstmiddel-1830.html permanent
  redir /product/mirka-polarshine-e3-glas-polijstmiddel-250ml/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-polarshine-e3-glas-polijstmiddel-1830.html permanent
  redir /product/mirka-polarstar-schuurschijven-150mm/* https://polyestershoppen.nl/koopjeshoek/uitverkoop-mirka-polarstar-150mm-10-stuks-1843.html permanent
  redir /product/mirka-polijstmachine-ps1437-150mm/* https://polyestershoppen.nl/polijsten/mirka-ps1437-polijstmachine-150mm-1849.html permanent
  redir /product/mirka-polijstvacht-lamswol-150mm/* https://polyestershoppen.nl/polijsten/mirka-polijstvacht-lamswol-1845.html permanent
  redir /product/mirka-polijstvacht-lamswol-180mm/* https://polyestershoppen.nl/polijsten/mirka-polijstvacht-lamswol-1845.html permanent
  redir /product/mirka-polijstvacht-lamswol-77mm/* https://polyestershoppen.nl/polijsten/mirka-polijstvacht-lamswol-1845.html permanent
  redir /product/mirka-schuurstofzuiger-1230l-push-clean/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stofzuiger-1230-l-push-clean-1904.html permanent
  redir /product/mirka-steunschijf-150mm-15-gaten/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-steunschijf-150mm-1900.html permanent
  redir /product/mirka-steunschijf-77mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-steunschijf-77mm-1898.html permanent
  redir /product/mirka-stofslang-4-meter-ceros-deros/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stofslang-813.html permanent
  redir /product/mirka-stofzakken-fleece-voor-915/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stofzuigerzakken-1031.html permanent
  redir /product/mirka-stofzuiger-1025-l/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stofzuiger-1025-l-812.html permanent
  redir /product/mirka-stofzuigerzakken-voor-1025/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-stofzuigerzakken-1031.html permanent
  redir /product/mirka-systainer-derosceros-400x300x158mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-systainers-opbergkoffer-1908.html permanent
  redir /product/mirka-vilt-polijstpad-125mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-vilt-polijstpads-2-stuks-1285.html permanent
  redir /product/mirka-vilt-polijstpad-77mm/* https://polyestershoppen.nl/schuren-en-polijsten/mirka-vilt-polijstpads-2-stuks-1285.html permanent
  redir /product/mirka-waterproof-handschuurvellen-280x230mm/* https://polyestershoppen.nl/schuren-en-polijsten/waterproof-schuurpapier-per-doos-898.html permanent
  redir /product/mirka-zachte-interface-pad-6-gaten-77mm/* https://polyestershoppen.nl/schuren-en-polijsten/interface-pad-1171.html permanent
  redir /product/mirka-zachte-interface-pad-67-gaten-150mm/* https://polyestershoppen.nl/schuren-en-polijsten/interface-pad-1171.html permanent
  redir /product/polish-applicator-sponge/* https://polyestershoppen.nl/polijsten/martin-cox-polijstspons-1952.html permanent
  redir /product/polish-dressing-applicator-pad/* https://polyestershoppen.nl/polijsten/polish-wax-handapplicator-pad-1951.html permanent
  redir /product/pp-wasset-luxe/* https://polyestershoppen.nl/reinigen/luxe-wasbox-set-1959.html permanent
  redir /product/raamwisser-fleece-30cm-voor-telescoopsteel/* https://polyestershoppen.nl/reinigen/martin-cox-raamwisser-voor-telescoopsteel-fleece-1936.html permanent
  redir /product/raamwisser-met-spons-voor-telescoopsteel/* https://polyestershoppen.nl/reinigen/martin-cox-raamwisser-voor-telescoopsteel-spons-1937.html permanent
  redir /product/riwax-excentrische-schuur-en-waxmachine/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-excentrische-schuurmachine-227.html permanent
  redir /product/riwax-polijstmachine-1300-watt/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-polijstmachine-1300-watt-226.html permanent
  redir /product/riwax-polijstmachine-150mm/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-polijstmachine-1100-watt-603.html permanent
  redir /product/riwax-polijstpad-175mm/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-polijstpad-175mm-615.html permanent
  redir /product/riwax-rs-02-compound-medium/* https://polyestershoppen.nl/bootonderhoud/riwax-rs-02-compound-medium-231.html permanent
  redir /product/riwax-rs-04-compound-fine/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-rs-04-compound-fine-232.html permanent
  redir /product/riwax-rs-06-hoogglans-polish/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-rs-06-hoogglans-polish-233.html permanent
  redir /product/riwax-rs-08-star-finish/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-rs-08-star-finish-237.html permanent
  redir /product/riwax-rs-10-hard-wax/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-rs-10-hard-wax-238.html permanent
  redir /product/riwax-rs-boat-clean/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-rs-boat-clean-248.html permanent
  redir /product/riwax-rs-wax-shampoo/* https://polyestershoppen.nl/schuren-en-polijsten/riwax-rs-wax-shampoo-838.html permanent
  redir /product/rupes-bigfoot-lhr15es-lux-polijstmachine/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-bigfoot-lhr15es-lux-polijstmachine-1361.html permanent
  redir /product/rupes-bigfoot-lhr21iii-lux-polijstmachine/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-bigfoot-lhr21iii-lux-polijstmachine-1362.html permanent
  redir /product/rupes-bigfoot-lhr75e-lux-polijstmachine/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-bigfoot-lhr75e-lux-polijstmachine-1360.html permanent
  redir /product/rupes-da-coarse-polijstpad-grof/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-da-coarse-polijstpad-grof-462.html permanent
  redir /product/rupes-da-coarse-polijstpasta/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-da-coarse-polijstpasta-1348.html permanent
  redir /product/rupes-da-fine-polijstpad-fijn/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-da-fine-polijstpad-fijn-1367.html permanent
  redir /product/rupes-da-fine-polijstpasta/* https://polyestershoppen.nl/schuren-en-polijsten/rupes-da-fine-polijstpasta-1358.html permanent
  redir /product/snow-foam-gun/* https://polyestershoppen.nl/reinigen/snow-foam-gun-1883.html permanent
  redir /product/snowfoam-adaptor/* https://polyestershoppen.nl/reinigen/snow-foam-gun-1883.html permanent
  redir /product/snowfoam-gun/* https://polyestershoppen.nl/reinigen/snow-foam-gun-met-tuinslangaansluiting-1885.html permanent
  redir /product/soft-detailling-brush/* https://polyestershoppen.nl/reinigen/5-delige-kwastenset-voor-car-detailing-1848.html permanent
  redir /product/sundstrom-sr218-gasfilterpatroon-a1/* https://polyestershoppen.nl/persoonlijke-bescherming/sundstrom-sr-217-filterpatroon-a1-1288.html permanent
  redir /product/sundstrom-sr221-voorfilters/* https://polyestershoppen.nl/persoonlijke-bescherming/sundstrom-sr-221-pre-filters-set-a-5-1292.html permanent
  redir /product/sundstrom-sr510-filterpatroon-p3/* https://polyestershoppen.nl/persoonlijke-bescherming/sundstrom-sr510-filterpatroon-p3-1221.html permanent
  redir /product/vervangings-wasborstel-telescoopsteel/* https://polyestershoppen.nl/reinigen/martin-cox-wasborstels-1852.html permanent
  redir /product/wasborstel-25-meter/* https://polyestershoppen.nl/reinigen/telescoopsteel-2-5-meter-1839.html permanent
  redir /product/wasborstel-zacht-voor-telescoopsteel/* https://polyestershoppen.nl/reinigen/martin-cox-wasborstels-1852.html permanent
  redir /product/washandschoen-met-vingers/* https://polyestershoppen.nl/reinigen/washandschoen-met-vingers-1884.html permanent
  redir /product/waterproof-schuurpapier/* https://polyestershoppen.nl/schuren-en-polijsten/schuurpapier-180.html permanent
  redir /product/zachte-borstel-voor-bumper-kunststof/* https://polyestershoppen.nl/reinigen/martin-cox-bumper-dorpel-borstel-1935.html permanent
  redir /shop/* https://polyestershoppen.nl/ permanent
  redir /zelf-autolak-krassen-verwijderen/* https://polyestershoppen.nl/info/autokras-verwijderen-zo-herstel-je-lakschade-aan-je-auto permanent
  # everything else
  redir https://polyestershoppen.nl/ permanent
    output file /var/log/caddy/poetsenpolijsten.log {
    format json
cronitor.polyestershoppen.nl {
  import blacklist
  abort @blacklist
  reverse_proxy localhost:9000 {
    output file /var/log/caddy/cronitor.log {
    format json
Ideally I do want to discard any redirect logging though yes. But as I see lots of redirects in my journald caddy log.. something is amiss with my logging setup I assume.
What version of Caddy are you using? That matters.
Sorry, using v2.10.2 h1:g/gTYjGMD0dec+UgMw8SnfmJ3I9+M2TdvoRL/Ovu6U8=
Okay. Adapting your Caddyfile to JSON, I think it’s clear what happens.
In your :80 server, there’s this:
					"logs": {
						"logger_names": {
							"poetsenpolijsten.nl": [
								"log5"
							"www.poetsenpolijsten.nl": [
								"log5"
						"skip_hosts": [
							"development.polyestershoppen.be",
							"development.polyestershoppen.com",
							"development.polyestershoppen.fr",
							"development.polyestershoppen.nl",
							"www.polyestershoppen.be",
							"www.polyestershoppen.com",
							"www.polyestershoppen.fr",
							"www.polyestershoppen.nl"
This happens because of this site block in your Caddyfile, which has a log config in it:
Because this site block has http:// it adds logging config to the :80 server, but the list of skipped hosts is incomplete, so it neither skips logging nor routes it to a specific logger, so it falls through to the default logger which sends it to stdout.
Remove your http:// site addresses from that site block, and it’s fixed.
The reason I have that block though is to get rid of any unneeded intermediate redirects (so http://olddomain.tld goes straight to https://newdomain.tld, rather than http://oldhttps://oldhttps://new).
Or am I wrong and would that be the default behaviour?
Letting the intermediate redirects is the simplest config that does what you want. It’s super fast anyway.
Otherwise, split out your redir stuff into a snippet, make two site blocks, one for HTTP and other for HTTPS, put logging config in HTTPS only, and import the snippet for redirects in both.
Alright, thanks for clarifying! I can work with this, much appreciated.
