I’m trying to use the same Caddyfile in production and in local development, and rely to variables for the minor changes, such as domain names. I’m using self-created certificates for local https. Everything is working perfectly. Except that now in my caddyfile I have declared something like this:
{$DOMAIN:localhost} {
tls /certs/site.crt /certs/site.key
root * /srv/www/landing-page
On the server side this whole tls
row should not exist, for caddy to setup the https automatically. It works fine if I remove it, but I want to be able to do it dynamically. I want to minimize the need for additional scripts or tools for changing config files. So I figured something like this should do it
{$PROD_HARMLESS_STRING:"tls /certs/site.crt /certs/site.key"}
Variables are served to the caddy container from docker compose using an env-file.
version: "3"
caddynet:
driver: bridge
image: caddy:latest
- 443:443
- ./certs:/certs
- ./landing-page:/srv/www/landing-page
- /opt/caddy/config:/config
- /opt/caddy/data:/data
env_file:
- vars.env
- caddynet
And the env file looks like this
DOMAIN=example.com
PROD_HARMLESS_STRING="vars /foo* isFoo 'yep'"
I took it from the examples for vars directive use in Caddyfile. But the container won’t run properly, and from docker logs I can see:
"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:2: unrecognized directive: vars /foo* isFoo 'yep'
I tried everything I could come up with inside the PROD_HARMLESS_STRING
, spaces, newlines, vars directive usage without matcher… I got the unrecognized directive error every time, even with whitespace, the error just desrcribing what I had in the variable. I’m stumped.
I know this whole approach is a bit “hacky” so I’m open to suggestions. I just want something semi-clean and simple.
Docker compose as described above.
Ubuntu 20.04.6 LTS
docker-compose up -d
Compose file provided above.
Caddyfile provided above.
