Apache behind Caddy reverse proxy
So I am using a web app when users can connect their custom domain to their profiles.
My configuration majorly includes Apache, PHP and MySQL
So I changed my default port 80 to 8080 - this is my apache port file
If you just change the port or add more ports here, you will likely also
# If you just change the port or add more ports here, you will likely also
# have to change the VirtualHost statement in
# /etc/apache2/sites-enabled/000-default.conf
Listen 8080
# <IfModule ssl_module>
# 	Listen 443
# </IfModule>
# <IfModule mod_gnutls.c>
# 	Listen 443
# </IfModule>
Installed caddy on my server and edited my caddy file to use my domain name
    email myemail
mydomain {
  reverse_proxy / localhost:8080
Correct me if I need to add something in caddy file, Im pretty new to caddy server. Also am I point it correctly to my apache port?
Config.json:
  "apps": {
    "tls": {
      "automation": {
        "policies": [
            "issuer": {
              "module": "acme",
              "email": "myemail"
            "on_demand": true
        "on_demand": {
          "rate_limit": {
            "interval": "5m",
            "burst": 100
    "http": {
      "http_port": 80,
      "https_port": 443,
      "servers": {
        "tiendas": {
          "listen": [":80", ":443"],
          "max_header_bytes": 41943040,
          "routes": [
              "handle": [
                  "handler": "reverse_proxy",
                  "upstreams": [
                      "dial": "localhost:8080"
              "terminal": true
For now I did not use “ask” directive as I dont exactly know what url to pass in and how it performs!
So this has been my configuration so far as Apache behind caddy reverse proxy, but when I visit my main domain I only the plain html is loaded and css/js are not loaded.
Also my other pages are not accessible, only main domain. And when I map my other domain(users custom domain), it doesn’t load.
Can someone please help, I can really use some help!!
Why do you have / in this line:
I am not sure that is your intent, but I could be wrong. Read about how request matchers work here: Request matchers (Caddyfile) — Caddy Documentation - that should answer the question!
It worked, thankyou!!
But I still cannot generate ssl for my custom domain pointing to my server with cname do not load “This site can’t provide a secure connection”
Error:
"http","msg":"user server is listening on same interface as automatic HTTP->HTTPS redirects; user-configured routes might override these settings"
"http","msg":"enabling automatic TLS certificate management","domains":["maindomain.com"]}
All errors are same as this one.
I think this is something to do with tls on demand and ask directive, can someone please help me figure out this issue!
I would really appreciate your reply!!
