I’m interested to switch two of my sites to Caddy 2 but these use wildcard domains registered with Namecheap.
Is it possible to configure Caddy 2 to handle automatic wildcard SSL certificate renewal for domains on Namecheap?
Welcome Csaba –
Yep, Caddy supports the DNS challenge (which is required for wildcard certificates if using Let’s Encrypt) for 75+ DNS providers: How to use DNS provider modules in Caddy 2
Did you manage to achieve this?
If so, how?
@nikola I know you’re not asking me, but that link I posted above is the answer.
Thanks, Matt!
My bad - I wasn’t looking at it tbh
I’m investigating
Cheers!
Did you get this working?
