I’m trying to convert this part of a .htaccess file to caddy
RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule ^(.*)$ index.php?q=$1 [L,QSA]
and I’m currently using this rewrite rule in caddy
rewrite / {
to {path} {path}/ /maintenance.html /index.php?q={path}&{query}{fragment}
I can’t spot my mistake but the underlying php application doesn’t behave like it did with apache.
Can you guys help me?
I’ve traced the problem down to leading slashes.
Apache gave the application $_REQUEST[‘q’] = ‘foo/bar/’
where caddy sets it to $_REQUEST[‘q’] = ‘/foo/bar/’
My current workaround is left trimming slashes inside the application. Is there a way to do this with caddy to fully clone the apache behaviour?
I guess it could potentially break a lot of application if they use the path without input sanitizing as a condition like
if ($_REQUEST['q'] == '/foo/') {
do_foo_stuff();
} else if ($_REQUEST['q'] == '/bar/') {
do_bar_stuff();
Personally I wouldn’t strip the slashes because why should caddy clone apache’s mistakes?
[trump voice]Caddy isn’t intended to be a clone but a better webserver. Make the web great again![/trump]
…ehm… yeah. Excuse me
