I use a Caddyfile from the API Platform samples. My backend is Symfony, my frontend is Angular. When I call the site, it shows /login and I can navigate through various pages. But once I hit refresh on any frontend route, it gives me an (nginx) 404 Error Page.
404 Page
Via Docker Compose
Debian with a Docker Environment
docker compose up -d
# Debug
{$CADDY_DEBUG}
{$SERVER_NAME}
log
@pwa expression `(
header({'Accept': '*text/html*'})
&& !path(
'/docs*', '/graphql*', '/bundles*', '/contexts*', '/_profiler*', '/_wdt*', '/api*', '/auth',
'*.json*', '*.html', '*.csv', '*.yml', '*.yaml', '*.xml'
|| path('/assets*', '/favicon.ico', '/manifest.json', '/robots.txt', '/*.css', '/*.js', '/sitemap*', '*.webmanifest', '/ngsw.json', '/login')`
route {
root * /srv/app/public
mercure {
transport_url {$MERCURE_TRANSPORT_URL:bolt:///data/mercure.db}
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
anonymous
subscriptions
{$MERCURE_EXTRA_DIRECTIVES}
vulcain
header ?Link `</docs.jsonld>; rel="http://www.w3.org/ns/hydra/core#apiDocumentation", </.well-known/mercure>; rel="mercure"`
header ?Permissions-Policy "browsing-topics=()"
reverse_proxy @pwa http://{$PWA_UPSTREAM}
php_fastcgi unix//var/run/php/php-fpm.sock
encode zstd gzip
Docker Compose File
version: "3.6"
ofelia:
image: mcuadros/ofelia:latest
depends_on:
- php
command: daemon --docker
php:
build:
context: .
target: app_php
args:
SYMFONY_VERSION: ${SYMFONY_VERSION:-}
STABILITY: ${STABILITY:-stable}
- php_socket:/var/run/php
- jwt:/srv/app/config/jwt
healthcheck:
interval: 10s
timeout: 3s
retries: 3
start_period: 30s
# Run "composer require symfony/orm-pack" to install and configure Doctrine ORM
DATABASE_URL: postgresql://${POSTGRES_USER:-app}:${POSTGRES_PASSWORD:-!ChangeMe!}@database:5432/${POSTGRES_DB:-app}?serverVersion=${POSTGRES_VERSION:-15}
TRUSTED_PROXIES: ${TRUSTED_PROXIES:-127.0.0.0/8,10.0.0.0/8,172.16.0.0/12,192.168.0.0/16}
TRUSTED_HOSTS: ^${SERVER_NAME:-example\.com|localhost}|caddy$$
MERCURE_URL: ${CADDY_MERCURE_URL:-http://caddy/.well-known/mercure}
MERCURE_PUBLIC_URL: https://${SERVER_NAME:-localhost}/.well-known/mercure
MERCURE_JWT_SECRET: ${CADDY_MERCURE_JWT_SECRET:-!ChangeThisMercureHubJWTSecretKey!}
pwa:
build:
context: .
target: app_ui
NEXT_PUBLIC_ENTRYPOINT: http://caddy
build:
context: .
target: app_caddy
depends_on:
- php
- pwa
PWA_UPSTREAM: pwa:80
SERVER_NAME: ${SERVER_NAME:-localhost}, caddy:80
MERCURE_PUBLISHER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeThisMercureHubJWTSecretKey!}
MERCURE_SUBSCRIBER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeThisMercureHubJWTSecretKey!}
- caddy_data:/data
- caddy_config:/config
- ./docker/php/nginx.conf:/etc/nginx/conf.d/default.conf:ro
# HTTP
- target: 80
published: ${HTTP_PORT:-80}
protocol: tcp
# HTTPS
- target: 443
published: ${HTTPS_PORT:-443}
protocol: tcp
# HTTP/3
- target: 443
published: ${HTTP3_PORT:-443}
protocol: udp
# Mercure is installed as a Caddy module, prevent the Flex recipe from installing another service
###> symfony/mercure-bundle ###
###< symfony/mercure-bundle ###
###> doctrine/doctrine-bundle ###
database:
image: postgres:${POSTGRES_VERSION:-15}-alpine
POSTGRES_DB: ${POSTGRES_DB:-app}
# You should definitely change the password in production
POSTGRES_PASSWORD: ${POSTGRES_PASSWORD:-!ChangeMe!}
POSTGRES_USER: ${POSTGRES_USER:-app}
- database_data:/var/lib/postgresql/data:rw
###< doctrine/doctrine-bundle ###
php_socket:
caddy_data:
caddy_config:
jwt:
database_data:
My Nginx Config
server {
listen 80;
server_name my-website.com;
location / {
proxy_pass http://caddy:80;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
