v2.4.3
Debian 10 x64
Folder structure inside test project:
caddy (caddy executable)
Caddyfile
myapp (Angular project)
./caddy run
No service or docker-compose file.
auto_https off
http://localhost:8080 {
handle /app/* {
root * myapp/dist/myapp
try_files {path} {path}/ /index.html
I want to serve my Angular App from the sub directory. By example: http://localhost:8080/app should display the Angular Application. But it doesn’t work.
The Angular App is build with:
ng build -- --base-href '/app/' --deploy-url '/app/'
http://localhost:8080/app → index.html not found
http://localhost:8080/app/ → index.html found but without resources
http://localhost:8080/app/index.html → index.html found but without resources
- Compile the Angular app without base-href and deploy-url parameters.
- Following configuration works if not in in a sub directory:
auto_https off
try_files {path} /
