I’m trying to run a reverse proxy thru DuckDNS to have my Jellyfin server remotely accessible.
I have downloaded Caddy and made a Caddyfile, and ran Caddy thru the Windows Powershell, as well as thru a .bat file but keep getting the error message “An attempt was made to access a socket in a way forbidden by its access permissions.”
Ports 443 and 80 are allowed in Windows Firewall and Port-Forwarded on my router.
2024/06/18 03:34:59.859 ←[34mINFO←[0m using adjacent Caddyfile
2024/06/18 03:34:59.861 ←[34mINFO←[0m adapted config to JSON {"adapter": "caddyfile"}
2024/06/18 03:34:59.861 ←[33mWARN←[0m Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 5}
2024/06/18 03:34:59.868 ←[34mINFO←[0m admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/06/18 03:34:59.868 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc000512800"}
2024/06/18 03:34:59.868 ←[34mINFO←[0m http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/06/18 03:34:59.869 ←[34mINFO←[0m http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/06/18 03:34:59.869 ←[35mDEBUG←[0m http.auto_https adjusted config {"tls": {"automation":{"policies":[{}]}}, "http": {"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:8096"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
2024/06/18 03:34:59.869 ←[33mWARN←[0m tls unable to get instance ID; storage clean stamps will be incomplete
{"error": "invalid UUID length: 0"}
2024/06/18 03:34:59.870 ←[34mINFO←[0m tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc000512800"}
Error: loading initial config: loading new config: http app module: start: listening on :443: listen tcp :443: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
This will sometimes change from port TCP:443 to TCP:80.
v2.8.4
From Releases · caddyserver/caddy · GitHub, selected the caddy_2.8.4_windows_amd64.zip release, extracted the .ZIP file to desktop, made the Caddyfile, and ran Caddy from Powershell.
PS C:\Users\Administrator> cd C:\Users\Administrator\Desktop\caddy\
PS C:\Users\Administrator\Desktop\caddy> .\caddy run
I even tried making a .bat an running from there.
pause
Microsoft Windows Server 2022
Version 21H2 (OS Build 20348.2527)
x64 bit
Powershell
.bat File
pause
N/A
jellyfin.lunmar.duckdns.org {
reverse_proxy localhost:8096
I have also tried adding
auto_https disable_redirects
from a Reddit search for the solution to the top of the Caddyfile which doesn’t work.
Used this guide to set-up:
https://www.reddit.com/r/jellyfin/s/PLQ5kLzUah
Sample Caddyfile:
https://pastebin.com/raw/9MCkLFyX
