All directives are rejected (except copy_response_headers) in handle_response section
Use Caddyfile to add header in handle_response section of reverse_proxy but adapter rejects the configuration.
Error: parsing caddyfile tokens for 'reverse_proxy': unrecognized directive: header_down - are you sure your Caddyfile structure (nesting and braces) is correct?, at /etc/caddy/Caddyfile:15
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’ | sudo tee /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
Ubuntu 24.04 in WSL2
caddy adapt --adapter="caddyfile" --config="/etc/caddy/Caddyfile" --pretty --validate
not relevant
:3001 {
		output file /var/log/caddy/year2024-access.log
	reverse_proxy localhost:3000 {
		@setcookie header Set-Cookie *
		handle_response @setcookie {
			header_down +X-Some-Header-Down {rp.header.Set-Cookie}
header_down isn’t a directive, it’s a subdirective of reverse_proxy. In other words, it’s only valid directly under reverse_proxy, not within handle_response which takes directives.
If you’re trying to add a header to the response, use header.
What subdirectives other than copy_response_headers can be used in handle_response of reverse_proxy? Thanks for helping.
No subdirectives of reverse_proxy at all can appear in handle_response. Only directives, plus as a special case, copy_response and copy_response_headers (as documented on reverse_proxy (Caddyfile directive) — Caddy Documentation)
In fact, i tried log_append in handle_response of reverse_proxy and it was rejected too. Should log_append be a directive and should it be allowed? Thanks again.
Show the error you got, and the config you tried.
Sorry, my fault. log_append works with handle_response. Thanks for helping.
