@francislavoie
Reran with debugging enabled in my caddyfile - logs:
text error warn system array login
{"level":"info","ts":1657999723.2637186,"logger":"tls.obtain","msg":"releasing lock","identifier":"calibre.nagpal.house"}
{"level":"error","ts":1657999723.2637308,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"jellyfin.nagpal.house","issuer":"acme.zerossl.com-v2-DV90","error":"[jellyfin.nagpal.house] solving challenges: getting authorization at https://acme.zerossl.com/v2/DV90/authz/jFt9sstwql-qS0-6zxECEw: attempt 1: https://acme.zerossl.com/v2/DV90/authz/jFt9sstwql-qS0-6zxECEw: context canceled (order=https://acme.zerossl.com/v2/DV90/order/eV5wBCZCAFgUN3P2y6TAfA) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"info","ts":1657999723.2637403,"logger":"tls.obtain","msg":"releasing lock","identifier":"jellyfin.nagpal.house"}
{"level":"error","ts":1657999723.2637076,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"cweb.nagpal.house","issuer":"acme.zerossl.com-v2-DV90","error":"[cweb.nagpal.house] solving challenges: getting authorization at https://acme.zerossl.com/v2/DV90/authz/-EdLXFR9FjNNk13Ta01Jlw: attempt 1: https://acme.zerossl.com/v2/DV90/authz/-EdLXFR9FjNNk13Ta01Jlw: context canceled (order=https://acme.zerossl.com/v2/DV90/order/SFLvgy5BXDvYvPqYKqr6hg) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"info","ts":1657999723.2637577,"logger":"tls.obtain","msg":"releasing lock","identifier":"cweb.nagpal.house"}
{"level":"error","ts":1657999723.2641063,"logger":"tls.obtain","msg":"unable to unlock","identifier":"bitwarden.nagpal.house","lock_key":"issue_cert_bitwarden.nagpal.house","error":"remove /data/caddy/locks/issue_cert_bitwarden.nagpal.house.lock: no such file or directory"}
{"level":"error","ts":1657999723.2641144,"logger":"tls","msg":"job failed","error":"bitwarden.nagpal.house: obtaining certificate: [bitwarden.nagpal.house] Obtain: [bitwarden.nagpal.house] solving challenges: getting authorization at https://acme.zerossl.com/v2/DV90/authz/_MrDpCJMhdciupHZ-SvWgQ: attempt 1: https://acme.zerossl.com/v2/DV90/authz/_MrDpCJMhdciupHZ-SvWgQ: context canceled (order=https://acme.zerossl.com/v2/DV90/order/wIErYq5dYTYXiyDgk_d38A) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1657999723.264154,"msg":"unable to clean up lock in storage backend","signal":"SIGTERM","storage":"FileStorage:/data/caddy","lock_key":"issue_cert_jellyfin.nagpal.house","error":"remove /data/caddy/locks/issue_cert_jellyfin.nagpal.house.lock: no such file or directory"}
{"level":"error","ts":1657999723.2642703,"msg":"unable to clean up lock in storage backend","signal":"SIGTERM","storage":"FileStorage:/data/caddy","lock_key":"issue_cert_cweb.nagpal.house","error":"remove /data/caddy/locks/issue_cert_cweb.nagpal.house.lock: no such file or directory"}
{"level":"error","ts":1657999723.2643871,"msg":"unable to clean up lock in storage backend","signal":"SIGTERM","storage":"FileStorage:/data/caddy","lock_key":"issue_cert_calibre.nagpal.house","error":"remove /data/caddy/locks/issue_cert_calibre.nagpal.house.lock: no such file or directory"}
{"level":"error","ts":1657999723.2644198,"logger":"tls","msg":"job failed","error":"calibre.nagpal.house: obtaining certificate: [calibre.nagpal.house] Obtain: [calibre.nagpal.house] solving challenges: getting authorization at https://acme.zerossl.com/v2/DV90/authz/4NEw5FKRTfCvoMf2T8fdrQ: attempt 1: https://acme.zerossl.com/v2/DV90/authz/4NEw5FKRTfCvoMf2T8fdrQ: context canceled (order=https://acme.zerossl.com/v2/DV90/order/AQsSk5KIfkBDaK8sWpHAuQ) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1657999723.2644253,"logger":"tls","msg":"job failed","error":"jellyfin.nagpal.house: obtaining certificate: [jellyfin.nagpal.house] Obtain: [jellyfin.nagpal.house] solving challenges: getting authorization at https://acme.zerossl.com/v2/DV90/authz/jFt9sstwql-qS0-6zxECEw: attempt 1: https://acme.zerossl.com/v2/DV90/authz/jFt9sstwql-qS0-6zxECEw: context canceled (order=https://acme.zerossl.com/v2/DV90/order/eV5wBCZCAFgUN3P2y6TAfA) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1657999723.2644296,"logger":"tls","msg":"job failed","error":"cweb.nagpal.house: obtaining certificate: [cweb.nagpal.house] Obtain: [cweb.nagpal.house] solving challenges: getting authorization at https://acme.zerossl.com/v2/DV90/authz/-EdLXFR9FjNNk13Ta01Jlw: attempt 1: https://acme.zerossl.com/v2/DV90/authz/-EdLXFR9FjNNk13Ta01Jlw: context canceled (order=https://acme.zerossl.com/v2/DV90/order/SFLvgy5BXDvYvPqYKqr6hg) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"info","ts":1657999723.266546,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
{"level":"info","ts":1657999723.2665534,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1657999730.4260795,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1657999730.4271452,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1657999730.4272208,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1657999730.4272323,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1657999730.4273078,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000228b60"}
{"level":"debug","ts":1657999730.4274888,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
{"level":"debug","ts":1657999730.4275055,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1657999730.427508,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["bitwarden.nagpal.house","jellyfin.nagpal.house","calibre.nagpal.house","cweb.nagpal.house"]}
{"level":"info","ts":1657999730.4275324,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1657999730.4277153,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1657999730.4282587,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1657999730.4282646,"msg":"serving initial configuration"}
{"level":"info","ts":1657999730.4283993,"logger":"tls.obtain","msg":"acquiring lock","identifier":"bitwarden.nagpal.house"}
{"level":"info","ts":1657999730.4286358,"logger":"tls.obtain","msg":"acquiring lock","identifier":"jellyfin.nagpal.house"}
{"level":"info","ts":1657999730.428811,"logger":"tls.obtain","msg":"acquiring lock","identifier":"cweb.nagpal.house"}
{"level":"info","ts":1657999730.4288852,"logger":"tls.obtain","msg":"acquiring lock","identifier":"calibre.nagpal.house"}
{"level":"info","ts":1657999730.4289362,"logger":"tls.obtain","msg":"lock acquired","identifier":"bitwarden.nagpal.house"}
{"level":"info","ts":1657999730.4290304,"logger":"tls.obtain","msg":"lock acquired","identifier":"jellyfin.nagpal.house"}
{"level":"info","ts":1657999730.4292834,"logger":"tls.obtain","msg":"lock acquired","identifier":"calibre.nagpal.house"}
{"level":"debug","ts":1657999730.429356,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
{"level":"info","ts":1657999730.4293745,"logger":"tls.obtain","msg":"lock acquired","identifier":"cweb.nagpal.house"}
{"level":"debug","ts":1657999730.4293842,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
{"level":"debug","ts":1657999730.4296257,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
{"level":"debug","ts":1657999730.430086,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
{"level":"info","ts":1657999730.4312441,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["bitwarden.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.431251,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["bitwarden.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.431439,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["calibre.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.431448,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["calibre.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.4316971,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["jellyfin.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.4317,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["cweb.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.4317045,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["jellyfin.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1657999730.431713,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["cweb.nagpal.house"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"debug","ts":1657999730.535791,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/directory","headers":{"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["658"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999730.5875864,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001s2ZQpG2OyC3SIkQqE5d6YiGqA5tUZE6Ch6EM4TKjxCI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999730.63538,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002dDAb6BUcVrfiQwYwSQacuQA9zE0WvYI_t2xLTmHL6Zw"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999730.6874774,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["00012_yYHVbAWF49_gCKHk1zKO2KouBjD3WHHT8HK73AJ3Y"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999730.7357428,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002KMLeU06bLkbtE-G-sbpLaZtDDQcSdm9SL1T27zPeSc8"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999730.8311255,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["213"],"Content-Type":["application/problem+json"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001AM0evZqJM7mlV-AEYG16dj6VPn6KgyGzEjCwRQM0sEA"],"Server":["nginx"]},"status_code":429}
{"level":"error","ts":1657999730.8312092,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"bitwarden.nagpal.house","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/"}
{"level":"debug","ts":1657999730.8312204,"logger":"tls.obtain","msg":"trying issuer 2/2","issuer":"acme.zerossl.com-v2-DV90"}
{"level":"info","ts":1657999730.8334243,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["bitwarden.nagpal.house"],"ca":"https://acme.zerossl.com/v2/DV90","account":""}
{"level":"info","ts":1657999730.833433,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["bitwarden.nagpal.house"],"ca":"https://acme.zerossl.com/v2/DV90","account":""}
{"level":"debug","ts":1657999730.9610531,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["346"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/634327066/107366699406"],"Replay-Nonce":["0002sxbwVr5m21RIjR7VLKr8_zhhClrndX9C0DhyBmlSSEA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
{"level":"debug","ts":1657999730.9617598,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["345"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/634327066/107366699266"],"Replay-Nonce":["00013W7wHVk3aZDSGk2F-EoIEBQ8j2XRDhhxz1Z84-E-eqk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
{"level":"debug","ts":1657999730.9838123,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["342"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/634327066/107366699506"],"Replay-Nonce":["0002GVjQWXzo3vSCNZr7QIsaofujE-CtQ_rx4aYAyPQOp7g"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
{"level":"debug","ts":1657999730.9959576,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/131280955336","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["805"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:50 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001D-nXte0xHfaaH2zmV9NQAsRz-uNfZ5AEOdLK8ZaSliY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999730.9960973,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"dns-01"}
{"level":"info","ts":1657999730.9961028,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"jellyfin.nagpal.house","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"debug","ts":1657999730.997639,"logger":"http.stdlib","msg":"http: TLS handshake error from 127.0.0.1:47730: EOF"}
{"level":"debug","ts":1657999731.0575242,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/131280955186","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["804"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:51 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001o-GA0DxhVrQ82_71lVHQxFaZSUlfmgDJT-fSsAeo5IQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999731.0575871,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"dns-01"}
{"level":"info","ts":1657999731.0575902,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"calibre.nagpal.house","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"debug","ts":1657999731.0585537,"logger":"http.stdlib","msg":"http: TLS handshake error from 127.0.0.1:47738: EOF"}
{"level":"debug","ts":1657999731.0978918,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/131280955446","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["801"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:51 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["00021VnSBLPRe44Q1YP4vqx59AjtSRG6Bb0HVRY3t6rJMyM"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999731.0979772,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"dns-01"}
{"level":"info","ts":1657999731.0979817,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"cweb.nagpal.house","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"debug","ts":1657999731.0987947,"logger":"http.stdlib","msg":"http: TLS handshake error from 127.0.0.1:47754: EOF"}
{"level":"debug","ts":1657999731.159109,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/131280955336/r_0B0A","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["191"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:51 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/131280955336>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/131280955336/r_0B0A"],"Replay-Nonce":["0002f_Kv8LxvqoqcpTly2zua9YtTbaXmlm_RdnnZDUAGjRA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999731.15916,"logger":"tls.issuance.acme.acme_client","msg":"challenge accepted","identifier":"jellyfin.nagpal.house","challenge_type":"tls-alpn-01"}
{"level":"debug","ts":1657999731.2054062,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/131280955186/OUEuXg","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["634327066"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["191"],"Content-Type":["application/json"],"Date":["Sat, 16 Jul 2022 19:28:51 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/131280955186>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/131280955186/OUEuXg"],"Replay-Nonce":["00011Vda5fffMs1kVumZEzHixoIaw7dGQp_WeO-CV3uIv-Q"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1657999731.2054656,"logger":"tls.issuance.acme.acme_client","msg":"challenge accepted","identifier":"calibre.nagpal.house","challenge_type":"tls-alpn-01"}
TBC
