After installing, error, Main process exited
1. Caddy version (2.4.6):
Not sure how to answer this.
I have just installed it from scratch on Ubuntu 18.04 following the guidelines from here ;
https://www.digitalocean.com/community/tutorials/how-to-host-a-website-with-caddy-on-ubuntu-18-04
I have also gone through this ;
https://caddyserver.com/docs/automatic-https
So I assume it just runs ?
Ubuntu 18.04
sudo systemctl status caddy
Tried  caddy start
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
http:// {
        root * /var/www
Just trying to get caddy running and to confirm it is running/working
root@vps-24424336:~# sudo systemctl status caddy
● caddy.service - Caddy
Active: failed (Result: exit-code) since Wed 2022-03-23 13:40:47 AEST; 31min ago
Docs: Welcome — Caddy Documentation
Process: 16084 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1
Main PID: 16084 (code=exited, status=1/FAILURE)
Mar 23 13:40:47 vps-24424336 caddy[16084]: {“level”:“info”,“ts”:1648006847.1479735,“logger”:“admin”,“msg”:"a
Mar 23 13:40:47 vps-24424336 caddy[16084]: {“level”:“info”,“ts”:1648006847.1484873,“logger”:“http”,“msg”:"se
Mar 23 13:40:47 vps-24424336 caddy[16084]: {“level”:“info”,“ts”:1648006847.1495445,“logger”:“tls”,“msg”:"cle
Mar 23 13:40:47 vps-24424336 caddy[16084]: {“level”:“info”,“ts”:1648006847.1498525,“logger”:“tls”,“msg”:"fin
Mar 23 13:40:47 vps-24424336 caddy[16084]: {“level”:“info”,“ts”:1648006847.150231,“logger”:"tls.cache.mainte
Mar 23 13:40:47 vps-24424336 caddy[16084]: {“level”:“info”,“ts”:1648006847.1504307,“logger”:"tls.cache.maint
Mar 23 13:40:47 vps-24424336 caddy[16084]: run: loading initial config: loading new config: http app module:
Mar 23 13:40:47 vps-24424336 systemd[1]: Started Caddy.
Mar 23 13:40:47 vps-24424336 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Mar 23 13:40:47 vps-24424336 systemd[1]: caddy.service: Failed with result ‘exit-code’.
I am not an Ubuntu type person, I am Windows, (although I have been in deep end IT for 44 years) so I am stumbling through Ubuntu as best and as intelligently as I can.
Tried a heap of Googling, reinstalled Caddy, made sure everything is as the instructions have dictated. Not sure what else to try.
Please disregard those installation instructions and instead follow the official docs:
DigitalOcean’s guide is overly complicated, providing no additional benefit. :roll_eyes: I really wish blog posts/articles would just link to the official installation instructions, because we maintain them, but often times those articles are not kept up to date.
Please take a look at this section in the docs to find the command to run to read your logs. Running systemctl status gives truncated log output, so you’re not seeing the actual error message.
