Kofl
(Kofl)
1
Hi,
Determine the simplest way to set globally, so its valid for all hosts or else use import per host?
@blocked {
header_regexp User-Agent Amazonbot*
handle @blocked {
error 403
There’s no way to configure global HTTP routes. Using snippets + import is the recommended way to reduce config duplication.
Please completely fill out the help topic template, as per the forum rules.
system
(system)
Closed
3
