Adding subpaths for a domain inside docker in caddy
I have used caddy inside my dockerfile. I need to add paths which point to another docker container.
I am pretty sure this should not work because it has reverse proxy. Please guide me. thanks.
Integrated inside my dockerfile
CentOS7
My complete Caddy config:
domain{
		Strict-Transport-Security "max-age=31536000; includeSubdomains; preload;"
		X-Content-Type-Options "no sniff"
		X-Frame-Options "DENY"
		Referrer-Policy "no-referrer-when-downgrade"
	root * /srv/public_html
	handle /socket/* {
		reverse_proxy localhost:8081 # http://chat:8006/;
	handle_path /api/* {
		reverse_proxy localhost:8082
		# reverse_proxy http://apserver:3000/;
the config that I had for this in nginx
localhost within a Docker container means “this container”. You’re not running any other server in that container, so that won’t work.
You should proxy to the name of your other container.
That said, you haven’t shown any actual error, so I have to guess. Please DO NOT delete any parts of the help topic template. It’s important that you completely fill it out.
