Adding module at download for V2
Hi everyone,
I was wondering if you were planning on doing the same thing as the V1 when you download the app.
It was possible the add module to the download (I guess it was loading it into caddy too).
If not, is it possible to add example to the documentation on how to load modules to caddy ?
I can’t find a clear “howto” to do it correctly (maybe I missed something).
Thanks in advance.
Regards,
Welcome, Fred –
We will someday. (Caddy 1 didn’t have that feature for about a year or more.) For now, the docs show how easy it is to build Caddy with plugins. You just need Go installed and xcaddy, then a single command to build Caddy:
Our wiki also lists known Caddy modules with instructions on how to build with them:
https://caddy.community/t/list-of-caddy-2-modules/7839/1
