if I pull caddy from master via “GO111MODULE=on go get github.com/mholt/caddy@master”, then I get the compiled binary in the “bin” folder in the GOROOT folder, but how can I tell go to add some plugins from github?
In the past “go getting” the repos worked, but with go mods and the latest master of caddy, my above command seems to already do every step to finish caddy, before i can intervene and add plugins.
Tried also without the GO111MODULE=auto var and v0.11.5, but I cant seem to get that to work.
