Add trailing slash to path
Ubuntu 20.04, docker, docker-compose
docker-compose up -d
version: '3'
    image: caddy
      - ./caddy/data:/data
      - ./caddy/config:/config
      - ~/www:/www
      - 443:443
  php:
    image: php:7.4-fpm-alpine
    container_name: php
    working_dir: /www
      - ~/www:/www
  root * /www
  php_fastcgi php:9000
  try_files {path}/index.html
I have the following files at ~/www : index.html and index.php.
Also in subfolder ~/www/test.com I have a second index.html and a photo01.JPG file:
<html>
<body>
  <h2>Test page</h2>
  <img src="photo01.JPG">
</body>
</html>
When I try http://serveraddress I can see the file index.html. If I remove this file, the index.php is served ok.
But if I try http://serveraddress/test.com I can see the “Test page” text but not the image.
If I try http://serveraddress/test.com/ (with the slash) I can see both the text and image.
How can the trailing / can be added to the URL?
I know that the solution must be very simple but I am a newbie in caddy and still learning.
I think this should work if you just leave out that try_files. php_fastcgi has its own try_files built-in so it shouldn’t be necessary to add in your own. But if it doesn’t work, it might with a fix that was just merged on the master branch.
@francislavoie
I added also a simple index.php in subfolder as a test.
I tried http://serveraddress/test.com without the try_files. Now the index.html is ignored and the index.php from the subfolder is served instead.
If I delete index.php from the subfolder, the index.php from the root is served!
I don’t understand why you would have two index files in the same directory though. That’s ambiguous.
That said, I think this might be fixed by a commit that just landed in the master branch yesterday. Previously try_files wasn’t properly handling the existence of directories, and therefore possibly index files in those directories.
I am just testing things. I am not going to let 2 index files on the same directory.
About the commit, is there any documentation on how to build the docker image with the latest code ?
Unfortunately it’s not quite so easy to build from source right now, but as soon as this is merged and deployed, it will be (hopefully today):
https://github.com/docker-library/official-images/pull/8735
We’re updating the builder image variant to use xcaddy, which will let you specify an arbitrary target to build from instead of only tagged releases.
