Add local certificates in Alpine container?
Hello !
I have some websites/services running locally in containers.
I use Caddy as a reverse proxy.
I need to access the url of a container (say https://domain1.local) from another container.
There comes a SSL problem :
curl: (60) SSL certificate problem: unable to get local issuer certificate
All the certificates are stored in /var/lib/caddy/.local/share/caddy/certificates/local/
I tried to add all .crt files to my container, but after many tries, can’t make HTTPS to work.
Do you have any idea how I can add my local certificates to the container ?
My container runs Alpine LInux 3.18.
Thank you :sunny:
Static binary, running as a service.
Fedora 36 x86_64
# Only reverse proxies like this
domain1.local {
    reverse_proxy 127.0.0.1:8001
See ssl - How to add trusted root CA to Docker alpine - Stack Overflow, this isn’t really a Caddy question, and rather a Alpine/Docker question.
@francislavoie Thank you for the answer.
I already tried that and other things before asking here, without luck.
I think i needed a clear explanation of what exactly I should add to the ca-certificate.crt.
But nevermind, I used caddy trust --address in the container and all is working now.
