Hello, last week caddy is enabled successfully , however, when I check it with "service caddy status", the message: ... Active: failed (Result: exit-code) ... , I have tried to stop nginx and re-load caddy but still fail, what should I do further to fix the issue ?
Welcome Grace,
What is the output of journalctl --no-pager -u caddy?
Hi Matt, thanks for response; the issue has been fixed by terminating nginx and restart caddy. ^^
