Actalis ACME: illegal base64 data at input byte 43
I’m trying to switch from the default certificate provider Let’s Encrypt to Actalis (free plan, unlimited single domain certificates), but I’m getting an error when requesting certificates:
could not get certificate from issuer
Obtain: base64-decoding MAC key: illegal base64 data at input byte 43
What I did was creating a global block in /etc/caddy/Caddyfile with the following content (keys have been invalidated):
    email me@example.com
    acme_ca https://acme-api.actalis.com/acme/directory
    acme_eab {
        key_id aiLRBKYhcWAVNeQHyPCRCePtXH
        mac_key IHxxLDCyqY7RTx9lz6ZMqD94rlBzw-znmVAis6OaiJQ=
Then I deleted everything under /var/lib/caddy/.local/share/caddy/certificates/acme-v02.api.letsencrypt.org-directory and restarted caddy with sudo systemctl restart caddy.
        "level": "info",
        "ts": 1761374887.3296335,
        "logger": "tls.issuance.acme",
        "msg": "creating new account because no account for configured email is known to us",
        "email": "me@example.com",
        "ca": "https://acme-api.actalis.com/acme/directory",
        "error": "open /var/lib/caddy/.local/share/caddy/acme/acme-api.actalis.com-acme-directory/users/me@example.com/actalis.json: no such file or directory"
        "level": "error",
        "ts": 1761374887.329879,
        "logger": "tls.obtain",
        "msg": "could not get certificate from issuer",
        "identifier": "example.com",
        "issuer": "acme-api.actalis.com-acme-directory",
        "error": "base64-decoding MAC key: illegal base64 data at input byte 43"
        "level": "error",
        "ts": 1761374887.3299177,
        "msg": "will retry",
        "error": "[example.com] Obtain: base64-decoding MAC key: illegal base64 data at input byte 43",
        "attempt": 1,
        "retrying_in": 60,
        "elapsed": 2.287067271,
        "max_duration": 2592000
From the Fedora COPR repo: https://copr.fedorainfracloud.org/coprs/g/caddy/caddy/
Fedora 42 with the CachyOS kernel.
sudo systemctl start caddy
Unmodified version of https://raw.githubusercontent.com/caddyserver/dist/master/init/caddy.service
# caddy.service
# for your installation.
Type=notify
It’s been working fine for months. It’s just Actalis ACME that’s acting wierd.
    acme_eab {
        key_id <my_key_id>
        mac_key <my_mac_key>
http:// {
    redir https://{host}{uri} permanent
https://example.com {
    reverse_proxy unix//run/navidrome/navidrome.socket
That MAC key is padded; remove the = sign.
