ACME DNS Challenging failing for sub-domain
We are trying to change Caddy to use an ACME dns-01 challenge to get around an issue with the Cloudflare proxying that prevents the standard http-01 acme challenge from completing successfully. We are unable to get the dns-01 challenge working.
Jun 22 06:39:03 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687415943.4292848,"logger":"tls.obtain","msg":"will retry","error":"[webci.blueshift.one] Obtain: [webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/ryB5fU0hEWvzH_tRixB-dA) (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":6.162394446,"max_duration":2592000}
Jun 22 06:40:03 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416003.4296691,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"webci.blueshift.one"}
Jun 22 06:40:05 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416005.001038,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"webci.blueshift.one","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 22 06:40:05 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416005.3027284,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"webci.blueshift.one","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.webci.blueshift.one\" (usually OK if presenting also failed)"}
Jun 22 06:40:05 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416005.5617292,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"webci.blueshift.one","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/107764524/9375309454) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 22 06:40:06 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416006.724421,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"webci.blueshift.one","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
Jun 22 06:40:06 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416006.9925613,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"webci.blueshift.one","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.webci.blueshift.one\" (usually OK if presenting also failed)"}
Jun 22 06:40:07 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416007.3817232,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"webci.blueshift.one","issuer":"acme.zerossl.com-v2-DV90","error":"[webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/VrD5wwdIxCOHIw1B0s-xGA) (ca=https://acme.zerossl.com/v2/DV90)"}
Jun 22 06:40:07 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416007.3818464,"logger":"tls.obtain","msg":"will retry","error":"[webci.blueshift.one] Obtain: [webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/VrD5wwdIxCOHIw1B0s-xGA) (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":70.114956545,"max_duration":2592000}
Jun 22 06:42:07 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416127.3821473,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"webci.blueshift.one"}
Jun 22 06:42:08 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416128.1655467,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"webci.blueshift.one","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 22 06:42:08 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416128.44892,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"webci.blueshift.one","challenge_type":"dns-01","error":"no memory of presenting a DNSrecord for \"_acme-challenge.webci.blueshift.one\" (usually OK if presenting also failed)"}
Jun 22 06:42:08 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416128.708666,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"webci.blueshift.one","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/107764524/9375331704) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 22 06:42:11 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416131.2563155,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"webci.blueshift.one","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
Jun 22 06:42:11 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416131.4966278,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"webci.blueshift.one","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.webci.blueshift.one\" (usually OK if presenting also failed)"}
Jun 22 06:42:12 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416132.0291429,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"webci.blueshift.one","issuer":"acme.zerossl.com-v2-DV90","error":"[webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/ZknktcxkhBjlXFnhITFZOw) (ca=https://acme.zerossl.com/v2/DV90)"}
Jun 22 06:42:12 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416132.0293689,"logger":"tls.obtain","msg":"will retry","error":"[webci.blueshift.one] Obtain: [webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/ZknktcxkhBjlXFnhITFZOw) (ca=https://acme.zerossl.com/v2/DV90)","attempt":3,"retrying_in":120,"elapsed":194.762478949,"max_duration":2592000}
Jun 22 06:44:12 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416252.0297399,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"webci.blueshift.one"}
Jun 22 06:44:12 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416252.8108354,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"webci.blueshift.one","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 22 06:44:13 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416253.1005056,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"webci.blueshift.one","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.webci.blueshift.one\" (usually OK if presenting also failed)"}
Jun 22 06:44:13 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416253.360279,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"webci.blueshift.one","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/107764524/9375352794) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 22 06:44:16 BSWEBCIWEB caddy[1424971]: {"level":"info","ts":1687416256.4304647,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"webci.blueshift.one","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
Jun 22 06:44:16 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416256.69554,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"webci.blueshift.one","challenge_type":"dns-01","error":"no memory of presenting a DNSrecord for \"_acme-challenge.webci.blueshift.one\" (usually OK if presenting also failed)"}
Jun 22 06:44:17 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416257.106103,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"webci.blueshift.one","issuer":"acme.zerossl.com-v2-DV90","error":"[webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/mGFlKG1ilLyetA-6zUR2Ew) (ca=https://acme.zerossl.com/v2/DV90)"}
Jun 22 06:44:17 BSWEBCIWEB caddy[1424971]: {"level":"error","ts":1687416257.106177,"logger":"tls.obtain","msg":"will retry","error":"[webci.blueshift.one] Obtain: [webci.blueshift.one] solving challenges: presenting for challenge: adding temporary record for zone \"webci.blueshift.one.\": expected 1 zone, got 0 for webci.blueshift.one. (order=https://acme.zerossl.com/v2/DV90/order/mGFlKG1ilLyetA-6zUR2Ew) (ca=https://acme.zerossl.com/v2/DV90)","attempt":4,"retrying_in":300,"elapsed":319.839286953,"max_duration":2592000}
v2.6.4
We install Caddy with a custom binary (includes Cloudflare dns provider) as a service on our Ubuntu server.
Ubuntu 22.04 LTS
# caddy.service
# for your installation.
Type=notify
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile --force
Caddyfile is as follows:
import /etc/caddy/global-config.caddy
import /etc/caddy/sites-enabled/*.caddy
webci.blueshift.one.caddy under /sites-enabled/ is as follows:
webci.blueshift.one {
        # <webci-beta-webui>
        handle /beta/one {
                reverse_proxy {
                        to localhost:50810
                                tls_trusted_ca_certs /etc/caddy/certificates/internal-ca/ca.pem
                        # Create a matcher for html content
                        @htmlContent {
                                header Content-Type text/html
                        # Handle html responses by cloning the response and Cache-Control to no-store.
                        # This is because WebUI html must be authenticated, we don't want it cached.
                        handle_response @htmlContent {
                                copy_response
                                copy_response_headers
                                header Cache-Control no-store
        handle /beta/one/* {
                reverse_proxy {
                        to localhost:50810
                        @htmlContent {
                                copy_response
        # </webci-beta-webui>
        # <RedirectionRule1> ENV=Beta&SERVICE=WebUI
        redir / https://webci.blueshift.one/beta/one permanent
        # </RedirectionRule1>
        # <RedirectionRulebeta-Deeplink>
        @HkjDtWA9 path_regexp ywhNArYc ^/beta/deeplink/(.+)$
        redir @HkjDtWA9 https://webciconnect.blueshift.one/EricomXml/accesssso/accessnowsso_oauth.htm?appName=webci%20-%20MilkyWay%20(Beta)%20Deeplinked&groupName=Beta&param1=deeplink={http.regexp.ywhNArYc.1} permanent
        # </RedirectionRulebeta-Deeplink>
        # <RedirectionRulebetaEnvRedirect>
        redir /beta https://webci.blueshift.one/beta/one permanent
        # </RedirectionRulebetaEnvRedirect>
        # <webci-beta-odataapi>
        handle /beta/odata {
                reverse_proxy {
                        to localhost:50811
        handle /beta/odata/* {
                reverse_proxy {
                        to localhost:50811
        # </webci-beta-odataapi>
        # <webci-beta-webui-tls>
        # </webci-beta-webui-tls>
        # <webci-beta-odataapi-tls>
        # </webci-beta-odataapi-tls>
global-config.caddy is as follows:
  acme_dns cloudflare [REDACTED]
Have been following instructions from: How to use Caddy with Cloudflare's SSL settings
FYI if you turn off strict mode in Cloudflare, it’ll allow HTTP requests through to Caddy instead of having Cloudflare redirect HTTP requests to HTTPS itself. Caddy can do the redirects anyway. That way HTTP-01 should work.
This is the same issue as error getting certificate for sub-subdomain · Issue #13 · caddy-dns/cloudflare · GitHub
I think the problem is that your local DNS resolver isn’t able to properly resolve that domain. The typical workaround is to override the DNS resolvers in your config to not use your local DNS resolver.
You can do this by using the tls directive instead of the acme_dns global option:
	dns cloudflare <api-key>
	resolvers 1.1.1.1
