Hi. I have the following devices in my local network:
- router (192.168.1.1)
- Synology NAS (192.168.1.3)
- PC (192.168.1.20)
80/443 ports are forwarded from router to NAS. On NAS I have configured DDNS *.superdomain.synology.me and certificate for it (Let’s Encrypt, derived using Synology UI). On PC I have local site running in docker container with Caddy inside with server name https://myservice.localhost.
In Synology reverse proxy I created subdomain myservice.superdomain.synology.me and configure the following rules:
HTTPS myservice.superdomain.synology.me 443 -> HTTPS 192.168.1.20 443
HTTP myservice.superdomain.synology.me 80 -> HTTP 192.168.1.20 80
but after that myservice.*.synology.me return me internal 502 Synology error page. I tried different solutions, but no luck. I believe problem with missing correct reverse_proxy directive Caddyfile and probably TLS, because with absolutely same settings in Synology reverse proxy I can successfully open other local sites on my PC inside docker (which use Nginx inside) using myservice.**.synology.me. What is the proper Caddyfile settings to achieve that?
3. Caddy version: 2.7.6
Ubuntu 22.04, Docker 25.0.3, Docker Compose v2.24.5
SERVER_NAME=myservice.localhost docker compose up -d
php:
image: ${IMAGES_PREFIX:-}app-php
SERVER_NAME: ${SERVER_NAME:-localhost}, php:80
MERCURE_PUBLISHER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeThisMercureHubJWTSecretKey!}
MERCURE_SUBSCRIBER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeThisMercureHubJWTSecretKey!}
TRUSTED_PROXIES: ${TRUSTED_PROXIES:-127.0.0.0/8,10.0.0.0/8,172.16.0.0/12,192.168.0.0/16}
TRUSTED_HOSTS: ^${SERVER_NAME:-example\.com|localhost}|php$$
# Run "composer require symfony/orm-pack" to install and configure Doctrine ORM
DATABASE_URL: postgresql://${POSTGRES_USER:-app}:${POSTGRES_PASSWORD:-!ChangeMe!}@database:5432/${POSTGRES_DB:-app}?serverVersion=${POSTGRES_VERSION:-15}&charset=${POSTGRES_CHARSET:-utf8}
# Run "composer require symfony/mercure-bundle" to install and configure the Mercure integration
MERCURE_URL: ${CADDY_MERCURE_URL:-http://php/.well-known/mercure}
MERCURE_PUBLIC_URL: https://${SERVER_NAME:-localhost}/.well-known/mercure
MERCURE_JWT_SECRET: ${CADDY_MERCURE_JWT_SECRET:-!ChangeThisMercureHubJWTSecretKey!}
# The two next lines can be removed after initial installation
SYMFONY_VERSION: ${SYMFONY_VERSION:-}
STABILITY: ${STABILITY:-stable}
- caddy_data:/data
- caddy_config:/config
# HTTP
- target: 80
published: ${HTTP_PORT:-80}
protocol: tcp
# HTTPS
- target: 443
published: ${HTTPS_PORT:-443}
protocol: tcp
# HTTP/3
- target: 443
published: ${HTTP3_PORT:-443}
protocol: udp
# Mercure is installed as a Caddy module, prevent the Flex recipe from installing another service
###> symfony/mercure-bundle ###
###< symfony/mercure-bundle ###
caddy_data:
caddy_config:
{$CADDY_GLOBAL_OPTIONS}
frankenphp {
{$FRANKENPHP_CONFIG}
# https://caddyserver.com/docs/caddyfile/directives#sorting-algorithm
order mercure after encode
order vulcain after reverse_proxy
order php_server before file_server
{$CADDY_EXTRA_CONFIG}
{$SERVER_NAME:localhost} {
# Redact the authorization query parameter that can be set by Mercure
format filter {
wrap console
fields {
uri query {
replace authorization REDACTED
root * /app/public
encode zstd br gzip
mercure {
# Transport to use (default to Bolt)
transport_url {$MERCURE_TRANSPORT_URL:bolt:///data/mercure.db}
# Publisher JWT key
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
# Subscriber JWT key
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
# Allow anonymous subscribers (double-check that it's what you want)
anonymous
# Enable the subscription API (double-check that it's what you want)
subscriptions
# Extra directives
{$MERCURE_EXTRA_DIRECTIVES}
vulcain
{$CADDY_SERVER_EXTRA_DIRECTIVES}
# Disable Topics tracking if not enabled explicitly: https://github.com/jkarlin/topics
header ?Permissions-Policy "browsing-topics=()"
php_server
