About localhost mutliple subfolder
mutliple site on localhost,i use symfony. i want:
http://192.168.100.100/a to vist a project
http://192.168.100.100/b to vist b project
when i vist http://192.168.100.100/a i got error:
No route found for “GET http://192.168.100.100/a
none
2.x
docker
    image: caddy
      - "443:443/udp"
      - ../:/var/www
      - ./caddy/data:/data
      - ./caddy/config:/config
  php:
    build:
      context: .
      dockerfile: ./php/Dockerfile
    container_name: php
    extra_hosts:
      - host.docker.internal:host-gateway
    privileged: true
      - "9000:9000"
      - ../:/var/www
http://192.168.100.100/a {
	root /a* /var/www/anti/public
	#reverse_proxy localhost:8002
	php_fastcgi php:9000
Please fill out the help topic template, as per the forum rules.
