Abort undefined subdomains when using wildcards and forward authorization
I use caddy with wildcards and Authelia. I want to modify my setup so if a subdomain is not defined, it is aborted. However, when I do so, Authelia still requires authorization before the abort is processed.
My Caddyfile currently looks like this:
auth.endpoint.internal {
    reverse_proxy authelia:9091
*.endpoint.internal {
    forward_auth authelia:9091 {
        uri /api/verify?rd=https://auth.endpoint.internal/
        copy_headers Remote-User Remote-Groups Remote-Email Remote-Name
    @srv1 host srv1.endpoint.internal
    handle @srv1 {
        respond "You are here"
        abort
Navigating to srv1.endpoint.internal redirects me to Authelia as expected.
However, attempting to navigate to other endpoints that are not defined (such as foo.endpoint.internal) also redirects me to Authelia. I want these “undefined” endpoints to result in an abort as well.
# endpoint defined in caddyfile, should respond
> curl 'https://srv1.endpoint.internal'
<a href="https://auth.endpoint.internal/?rd=https%3A%2F%2Fsrv1.endpoint.internal%2F&amp;rm=GET">302 Found</a>
# endpoint not defined in caddyfile, should abort
> curl 'https://foo.endpoint.internal'
<a href="https://auth.endpoint.internal/?rd=https%3A%2F%2Ffoo.endpoint.internal%2F&amp;rm=GET">302 Found</a>
If I remove the Authelia configuration from the Caddyfile:
    handle @srv1 {
        abort
I get the expected behavior - srv1 returns a response, while any other endpoints get aborted.
You are here
curl: (92) HTTP/2 stream 1 reset by server (error 0x2 INTERNAL_ERROR)
How can I achieve this behavior while still using forward_auth and Authelia?
v2.11.2 h1:iOlpsSiSKqEW+SIXrcZsZ/NO74SzB/ycqqvAIEfIm64=
Arch Linux x86_64 (Linux 6.19.11-arch1-1)
Docker version 29.4.0, build 9d7ad9ff18
Docker Compose version 5.1.3
SystemD 260.1-1-arch
docker compose up -d
    image: caddy
      - 443:443
      - 443:443/udp
      - /data/Caddyfile:/etc/caddy/Caddyfile
  authelia:
    image: authelia/authelia:latest
    container_name: authelia
      - /data/authelia:/config
With Caddy 2.10.0 and newer, you can do this:
    abort
srv1.endpoint.internal {
   // your SRV1 stuff
    handle @srv1 {
        abort
Here you go try this out and see if it work for you. I starting understand caddy language.
you can verify and test
curl -I https://srv1.endpoint.internal # 302 to Authelia
curl -I https://foo.endpoint.internal # connection reset / aborted
Thanks for the help. I ended up also putting the forward_auth declaration in a named route and using invoke so I don’t have to repeat the forward_auth declaration.
&(authelia) {
    abort
    invoke authelia
    respond "you are here"
That awesome you got it great work
If you want to take it a step further and also drop HTTP requests for undefined sites, you could do something like this:
	auto_https disable_redirects
&(authelia) {
    abort
    invoke authelia
http://srv1.endpoint.internal {
	redir https://srv1.endpoint.internal{uri} 308
http:// {
	abort
The only site left with HTTP, for HTTP-to-HTTPS redirect, is srv1.endpoint.internal. Everything else is HTTPS-only or dropped.
Some details here:
