"Abort" snippet for non-local IPs not working
I have many forwards. I want all of them to only allow local IPs (private_ranges). I tried it with a snippet and importing that one underneath my *.example.com, but it’s forwarding/allowing everything.
No error logs, since Caddy is just allowing everything. I can curl from a remote (public) IP and everything is allowed, even though it should be aborting non private_ranges
v2.10.2
Docker compose on Debian.
Debian VM on Proxmox, running docker compose (v5.1.0)
N/A
    build: .
    network_mode: host
      - ./conf:/etc/caddy
      - ./site:/srv
      - ./caddy_data:/data
      - ./caddy_config:/config
	email email@example.com
	acme_dns transip {
		login my_username
		private_key /etc/caddy/my_key.pem
(internal_only) {
    @not_private not remote_ip private_ranges
    abort @not_private
*.example.com {
	import internal_only
	@test host test.example.com
	handle @test{
		reverse_proxy 192.168.1.100:8880
Putting it all in a route block seems to be working, for example:
	acme_dns transip {
		login my_username
(internal_only) {
    abort @not_private
*.example.com {
	route {
		handle @test{
I’m just not sure if this would be the best pratice…
handle has higher priority than abort, so your traffic will never reach it unless someone tries to access something other than the sites you listed.
I’m on my phone right now, but I’ll post a better approach to your problem once I’m back on my computer, sorry.
In the meantime, take a look at the directive order:
As timelordx said, handle is sorted above abort so that’s why it fails, but when you wrap it in a route it disables the directive sorting so it forces abort to be first and you get the behaviour you expect. Alternatively, you could make your snippet have a handle around the abort (apply the matcher on the handle) then since the handles are at the same nesting level with eachother they will act mutually exclusively and the first one which matches (in the order they appear) will execute.
