KENHI_OU
(KENHI OU)
May 13, 2020, 5:58am
1
2.0.0
caddy start
Debian sid
After=network-online.target
Restart=on-abnormal
Type=forking
User=www-data
Group=www-data
WorkingDirectory=/etc/caddy
ExecStart=/usr/bin/caddy start
This is my caddyfile of caddy1.
example.com {
proxy / 127.0.0.1:8080{
proxy /ray 127.0.0.1:10000 {
websocket
header_upstream -Origin
I tried following config file but it didn’t work.
example.com
reverse_proxy localhost:8080
reverse_proxy /ray/* localhost:10000
How can I use caddy2 to do it?
“/” to :8080 but “/ray” to :10000
Google Search and read document.
Can you explain what exactly you’re having trouble with? That config looks pretty correct to me. What’s not working? What behaviour are you seeing? Anything in the logs?
Also, have you see the service file we provide for Caddy v2? I think you might still be using the one you were using for Caddy v1.
# caddy.service
# for your installation.
This file has been truncated. show original
KENHI_OU
(KENHI OU)
May 13, 2020, 9:01am
3
Thanks.
But I have a problem of Caddyfile, not daemon.I created it and works fine.
That’s nowhere near enough information. You need to elaborate! What’s the problem exactly?
vbakke
(Vegard Bakke)
May 13, 2020, 2:54pm
5
Are you testing with https://example.com/ray , og https://example.com/ray/something in the browser?
Where do you get an error? And what does the error say?
Vegard
dukeart
(Alex)
May 13, 2020, 3:56pm
6
You can try the same with nested directives for the host then the reverse_proxy using handle :
localhost {
handle /ray/* {
reverse_proxy localhost:10000
I think it’s a start .
Alex
system
(system)
Closed
June 12, 2020, 3:56pm
7
