Hello,
I am trying to host sites on subdomains of mine through Cloudflare. Sometimes routes will respond with 525
before returning a expected response after a few retries. I am extremely confused as to why.
On every curl -vL
I’ve tried of a subdomain, it occurs only the first time, and then not the second time.
The error does not occur on the main domain (eldon.zone/eldon.dev).
Thank you,
Eldon
2024/02/12 15:44:17.966 INFO using adjacent Caddyfile
2024/02/12 15:44:17.969 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//127.0.0.1:2019", "//localhost:2019", "//[::1]:2019"]}
2024/02/12 15:44:17.970 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/02/12 15:44:17.970 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/02/12 15:44:17.971 INFO http enabling HTTP/3 listener {"addr": ":443"}
2024/02/12 15:44:17.972 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/02/12 15:44:17.972 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/02/12 15:44:17.973 INFO http enabling automatic TLS certificate management {"domains": ["flowchart.eldon.dev", "eldon.zone", "eldon.dev", "*.eldon.zone", "*.eldon.dev"]}
2024/02/12 15:44:17.975 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2024/02/12 15:44:17.976 INFO serving initial configuration
2024/02/12 15:44:17.970 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0002b2100"}
2024/02/12 15:44:17.975 WARN tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/root/.local/share/caddy", "instance": "d5091c80-a7be-4ce7-9b61-7077546451eb", "try_again": "2024/02/13 15:44:17.975", "try_again_in": 86399.99999959}
2024/02/12 15:44:17.976 INFO tls finished cleaning storage units
Successfully started Caddy (pid=483680) - Caddy is running in the background
If there’s any other useful logs I could provide let me know.
Linode Unbuntu 22
caddy start
acme_dns cloudflare <REDACTED>
https://eldon.zone, https://eldon.dev {
reverse_proxy localhost:3000
https://flowchart.eldon.dev {
root * /root/flowchart-project/dist
https://*.eldon.zone, https://*.eldon.dev {
respond "This subdomain isn't being used currently!"
https://community.cloudflare.com/t/community-tip-fixing-error-525-ssl-handshake-failed/44256
