404 when load css/js use reverse_proxy
V2
docker-compose up -d
Docker
  web_server:
    image: caddy
    container_name: website-server
    depends_on:
      - ca
      - home
      - vol_home:/var/opt/website/home:ro
      - vol_ca:/var/opt/ca/:ro
#    @nextcloud_respond {
#        header X-USER-TYPE *nextcloud*
#    uri @nextcloud_respond replace / /nc/
    @nextcloud {
        path /nc
        path /nc/*
    route @nextcloud {
        rewrite /nc /
        uri strip_prefix /nc
        reverse_proxy https://XXXXXX.net:2443
#        reverse_proxy https://XXXXXX.net:2443 {
#            header_down X-USER-TYPE *nextcloud*
    route * {
        file_server * {
            root /var/opt/website/home
            index index.html index.htm
Sub folder error when use reverse_proxy!
The main html can be obtained normally but the internal css/js file path lacks prefix.
How can I fix this problem.
home:
Request URL: https://XXXXXX.com/nc
Request Method: GET
Status Code: 200
Remote Address: xxx.xxx.xxx.xxx:443
Referrer Policy: strict-origin-when-cross-origin
inner:
Request URL: https://XXXXXX.com/core/img/manifest.json
Request Method: GET
Status Code: 404
Remote Address: XXX.XXX.XXX.XXX:443
Referrer Policy: no-referrer
inner direct:
Request URL: https://XXXXXX.com/nc/core/img/manifest.json
Request Method: GET
Status Code: 304
I try to add a special header field to proxy respond and rewrite request path as commented but failed.
Is there an easy way to fix this problem or I must run multiple instances of caddy?
none
Basically, you’re running into this (as far as I understand from your post)
uri cannot rewrite responses, it only rewrites the request on the way in.
I’m not sure I understand what you’re trying to do though. Where is this file you’re trying to serve? Is it actually on disk at /var/opt/website/home/core/img/manifest.json? That’s where file_server is looking for it with your current config.
Please don’t forget to persist /data when running in Docker, especially when using Let’s Encrypt for certificates, otherwise you’re throwing away your certificates and keys every time you re-create your Caddy container. Docker
For what it’s worth, I’d write your config (what you have so far) like this:
    redir /nc /nc/
    handle_path /nc/* {
        root * /var/opt/website/home
        file_server {
Thanks for your reply!!!
I have two vps and domains, One is XXXXXX.com for gate, the other XXXXXX.net provides services through different port.
This Caddy is running on gate server( XXXXXX.com ) and has a static website local at /var/opt/website/home.
So that I can use https://XXXXXX.com to access home website and https://XXXXXX.com/xxx to access another server like nextcloud.
core/img/manifest.json is in XXXXXX.net. What I need is make sure the reponse from reverse_proxy also load css/js through reverse_proxy.
Applying for a CA through Let’s Encrypt is a terrible thing if you don’t have a store and waste all your opportunities in a week.Especially debug without --dry-run. I have already make a backup.
I test your solution but not work for this.
I’m not sure what you’re saying here. Yes, you’ll hit rate limits if you don’t have a volume that persists /data, like I said. If you add the volume, you won’t hit rate limits. You should use Let’s Encrypt’s ACME staging endpoint when you’re testing your setup, because it has looser rate limits (but its certificates re not trusted).
Why not just serve a subdomain like nc.example.com for nextcloud instead of serving it under a subpath? I think that would simplify things and fix your problem.
