I am building a website that has an home page and some reverse proxies on some paths. For example palmiotto.duckdns.org/jellyfin/ is pointing to the local jellyfin port.
Operating System: Ubuntu 20.10
Kernel: Linux 5.8.0-48-generic
Architecture: x86-64
caddy start
# caddy.service
# for your installation.
issuer acme {
disable_http_challenge
issuer zerossl {
#basicauth {
# xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
file_server browse
reverse_proxy /planes/* 192.168.1.134:8754
#reverse_proxy 192.168.1.134:8754
reverse_proxy /jellyfin/* 192.168.1.199:8096
handle_errors {
rewrite * /{http.error.status_code}
reverse_proxy https://http.cat {
header_up Host http.cat
If I try to access the path planes i get 403 forbidden
verbose curl GET request
* Trying 188.116.61.101:443...
* TCP_NODELAY set
* Connected to palmiotto.duckdns.org (188.116.61.101) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* subject: CN=palmiotto.duckdns.org
* start date: Mar 27 10:25:48 2021 GMT
* expire date: Jun 25 10:25:48 2021 GMT
* subjectAltName: host "palmiotto.duckdns.org" matched cert's "palmiotto.duckdns.org"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x55f4e270a7e0)
> GET /planes/ HTTP/2
> Host: palmiotto.duckdns.org
> user-agent: curl/7.68.0
> accept: */*
< HTTP/2 403
< server: Caddy
< content-type: text/plain; charset=utf-8
< content-length: 12
< date: Fri, 02 Apr 2021 18:03:39 GMT
* Connection #0 to host palmiotto.duckdns.org left intact
FORBIDDEN :>
If I remove the reverse proxy path for “planes” and the file_server directive, so that the service is located on the root of the website, everything seems to work just fine. How can i solve this behaviour?
