400 Error when connecting to upstream serverr
I’m trying to setup a simple reverse proxy using two servers.
My Caddy server is setup with only Ubuntu and Caddy. I have Caddy installed as a service on the Ubuntu server and it seems to be running correctly.
The reverse proxy is for surething.com connecting to the upstream server at sites.surething.com. sites.surething.com is directly accessible through a browser. But when I try to reverse proxy to it through surething.com I get a 400 error.
Both surething.com and site.surething.com point to the same IP address. Both also are setup as Virtual Hosts on Apache2.
I have a second reverse proxy in my Caddyfile using surethingtickets.com that goes directly to surething.com rather than going through sites.surething.com. This seems to be working as expected.
At this time, I can’t leave surething.com pointing to my Caddy server indefinitely, so the problem can’t be seen. I can enable it for short periods if/when it is helpful. I have attached a log showing the last time it was attempted.
The certificate on surething.com is a wildcard certificate, so it should cover both surething.com and sites.surething.com. When using the latest version of Chrome, going to surething.com fails with ERR_SSL_PROTOCOL_ERROR. Firefox works for both.
  I think the following logs will show the problem. If you
  have tips for formatting the logs for better readability, I'll use them.
Dec 12 22:12:30 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419150.9345016,"logger":"events","msg":"event","name":"tls_get_certificate","id":"d724d391-11ae-4c45-8280-152382f0a9f1","origin":"tls","data":{"client_hello":{"CipherSuites":[49196,49195,49200,49199,49188,49187,49192,49191,49162,49161,49172,49171,157,156,61,60,53,47,10],"ServerName":"www.surething.com","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[2052,2053,2054,1025,1281,513,1027,1283,515,514,1537,1539],"SupportedProtos":null,"SupportedVersions":[771,770,769],"Conn":{}}}}
Dec 12 22:12:30 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419150.9356413,"logger":"tls.handshake","msg":"choosing certificate","identifier":"www.surething.com","num_choices":1}
Dec 12 22:12:30 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419150.9357986,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"www.surething.com","subjects":["www.surething.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"7feb11d1748e00468863db01cbfaa458c15bc73766c869b3e93cdc13e8580026"}
Dec 12 22:12:30 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419150.936006,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"73.153.0.57","remote_port":"57313","subjects":["www.surething.com"],"managed":true,"expiration":1708357534,"hash":"7feb11d1748e00468863db01cbfaa458c15bc73766c869b3e93cdc13e8580026"}
Dec 12 22:12:31 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419151.1238923,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"sites.surething.com:443","total_upstreams":1}
Dec 12 22:12:31 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419151.2190392,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"sites.surething.com:443","duration":0.094498856,"request":{"remote_ip":"73.153.0.57","remote_port":"57313","client_ip":"73.153.0.57","proto":"HTTP/1.1","method":"GET","host":"surething.com","uri":"/assets/ajax/stajaxrequest.php?callback=jQuery17208629798286774354_1702419151258&request=appConfig&appdesc=stl7&lang=enu&country=USA&version=7.0.95.0&promo=DiscDeluxeGold7&token=YA7Y7224Y7H41F3K&_=1702419151455","headers":{"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["www.surething.com"],"Accept":["*/*"],"Accept-Language":["en-US"],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.2; WOW64; Trident/7.0; .NET4.0C; .NET4.0E; .NET CLR 2.0.50727; .NET CLR 3.0.30729; .NET CLR 3.5.30729; IPH 1.1.21.4019)"],"X-Forwarded-For":["73.153.0.57"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","server_name":"www.surething.com"}},"headers":{"Server":["Apache/2.4.10 (Ubuntu)"],"Content-Length":["306"],"Content-Type":["text/html; charset=iso-8859-1"],"Date":["Tue, 12 Dec 2023 22:12:31 GMT"]},"status":400}
Dec 12 22:12:34 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419154.0945315,"logger":"events","msg":"event","name":"tls_get_certificate","id":"6158f42a-388e-47a0-bd54-1be979c8186b","origin":"tls","data":{"client_hello":{"CipherSuites":[49196,49195,49200,49199,49188,49187,49192,49191,49162,49161,49172,49171,157,156,61,60,53,47,10],"ServerName":"www.surething.com","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[2052,2053,2054,1025,1281,513,1027,1283,515,514,1537,1539],"SupportedProtos":null,"SupportedVersions":[771,770,769],"Conn":{}}}}
Dec 12 22:12:34 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419154.0955908,"logger":"tls.handshake","msg":"choosing certificate","identifier":"www.surething.com","num_choices":1}
Dec 12 22:12:34 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419154.095854,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"www.surething.com","subjects":["www.surething.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"7feb11d1748e00468863db01cbfaa458c15bc73766c869b3e93cdc13e8580026"}
Dec 12 22:12:34 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419154.0960155,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"73.153.0.57","remote_port":"57320","subjects":["www.surething.com"],"managed":true,"expiration":1708357534,"hash":"7feb11d1748e00468863db01cbfaa458c15bc73766c869b3e93cdc13e8580026"}
Dec 12 22:12:34 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419154.1967027,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"sites.surething.com:443","total_upstreams":1}
Dec 12 22:12:34 Dig-Ocean04-Caddy caddy[372582]: {"level":"debug","ts":1702419154.2987998,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"sites.surething.com:443","duration":0.101521251,"request":{"remote_ip":"73.153.0.57","remote_port":"57320","client_ip":"73.153.0.57","proto":"HTTP/1.1","method":"GET","host":"surething.com","uri":"/swlinks/links.php?appdesc=stl7&base=billboards&lang=enu&country=USA&version=7.0.95.0&promo=DiscDeluxeGold7&token=YA7Y7224Y7H41F3K","headers":{"X-Forwarded-For":["73.153.0.57"],"User-Agent":["Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.0.3705)"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["www.surething.com"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","server_name":"www.surething.com"}},"headers":{"Content-Length":["306"],"Content-Type":["text/html; charset=iso-8859-1"],"Date":["Tue, 12 Dec 2023 22:12:34 GMT"],"Server":["Apache/2.4.10 (Ubuntu)"]},"status":400}
I installed Caddy on our Ubuntu server using the instructions for Debian, Ubuntu, Raspbian found on your site. Everything went quite smoothly and Caddy seems to be running as a service.
1 GB Memory / 25 GB Disk / SFO3 - Ubuntu 23.10 x64
Very plain Ubuntu server with nothing else installed. systems yes, docker no.
Not currently using any commands, running Caddy as a service. Using a Caddyfile for config.
Using systems but nothing else.
Very simple at this point:
https://surething.com, https://www.surething.com {
        reverse_proxy https://sites.surething.com {
                header_up Host surething.com
https://surethingtickets.com https://www.surethingtickets.com {
    reverse_proxy https://surething.com {
None currently.
6. Additional comments
The upstream is returning status 400, which means it doesn’t like the request.
You probably meant to do header_up Host sites.surething.com, or simpler, header_up Host {upstream_hostport}.
See the docs reverse_proxy (Caddyfile directive) — Caddy Documentation
My guess is that the upstream expects the Host to match, and since it doesn’t it returns an error.
Thank you, that did it and it seems to be running well now.
One more question, our goal is to have the reverse proxy handle the initial request and handshakes and then pass it off to the upstream server. Is our config enough to do this properly, or should we be exploring other settings in Caddy?
Thanks again!
That’s a vague question because it entirely depends on your needs.
OK. It is a vague question. Our needs are just what I described, passing all requests through to the upstream server. Maybe for this, the simple reverse proxy directive is all that is needed.
