3 step file delivery and reverse proxy
2.4
Ubuntu VM
sudo caddy run
dub.domain.net
                route * {
                        root * path/to/build/dir
                        try_files {path} try_files /index.html reverse_proxy 127.0.0.1:1338
I’m in the process of switching my deploymentprocess over to hosting all static files via caddy and also let it taking care of the reverse-proxy process.
The main issue I got now Is that I’m looking for the following behaviour:
  1. Check if path is /, in this case serve the index.html
  2. If there is a path, serve the file on that path, if it exists.
  3. If there is no file, reverse proxy everything the a server running on port 1338
I have a hard time getting to that logic, maybe someone can give me a hint in the right direction.
No errors, only wrong files delivered.
I’m trying different setups. I’m mainly thinking about creating one route for /, and then doing the rest with the try_files directive.
I was able to solve it with some searching arround and came up with this working solution:
mydomain.net
root * /path/to/build/dir
route / {
                route * {
                        @notStatic {
                                not {
                                        file {
                                                try_files {path}
                        reverse_proxy @notStatic 127.0.0.1:1338
What you have there isn’t valid syntax. The try_files directive doesn’t take other directives as arguments, it just takes file paths to try on disk, and will do a rewrite to that path for the first one that exists.
To do what you want, you should use request matchers and handle blocks.
example.com {
	@fileExists file
	handle @fileExists {
The handle directive is used to make the handling of these two paths mutual exclusive, and a handle without a matcher will always be the last one tried.
