tas
(Michal Maciejewski)
August 3, 2023, 9:18pm
1
Hi,
when I am building with
FROM caddy:2.7-builder-alpine AS builder
its pulling v2.7.0-beta.2
when I use
FROM caddy:2.7.2-builder-alpine AS builder
I get:
failed to solve: caddy:2.7.2-builder-alpine: docker.io/library/caddy:2.7.2-builder-alpine: not found
Has 2.7.2 been released on Docker Hub yet?
From the look of GH Actions it looks like yes, but how can I use it?
timelordx
(timelordx)
August 4, 2023, 4:06am
2
Right now it shows 2.7.2. But it also says it was pushed about an hour after you had posted your question here, so it’s hard to say what exactly the version was saying when you were trying to pull it.
tas
August 4, 2023, 4:29am
3
yeah, its weird
this is what I get when I build with FROM caddy:2.7.2-builder-alpine AS builder
caddy | caddy.HomeDir=/root
caddy | caddy.AppDataDir=/data/caddy
caddy | caddy.AppConfigDir=/config/caddy
caddy | caddy.ConfigAutosavePath=/config/caddy/autosave.json
caddy | caddy.Version=v2.7.0-beta.2.0.20230725185021-d7d16360d411 h1:Hq2Ph3i47imGFwMmyEb8g8ExG2G9ISJlQJ6R73ddb6E=
caddy | runtime.GOOS=linux
caddy | runtime.GOARCH=amd64
caddy | runtime.Compiler=gc
caddy | runtime.NumCPU=24
caddy | runtime.GOMAXPROCS=24
caddy | runtime.Version=go1.20.7
caddy | os.Getwd=/srv
caddy |
caddy | PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
caddy | HOSTNAME=7673b12e31cf
caddy | ADMIN_URL=bRs47jH13fdsBFMQ93
caddy | DOMAIN=local.vfxtricks.com
caddy | CADDY_VERSION=v2.7.2
caddy | XDG_CONFIG_HOME=/config
caddy | XDG_DATA_HOME=/data
caddy | HOME=/root
It says v2.7.0-beta.2.0.20230725185021-d7d16360d411 and v2.7.2. So I am confused which one is it running.
This output is from --environ flag when I run Caddy
timelordx
(timelordx)
August 4, 2023, 5:04am
4
Weird. Is it possible that you have your build cached? Could you try docker build with --no-cache ?
This is my Caddy container:
~ # cat /etc/os-release
NAME="Alpine Linux"
ID=alpine
VERSION_ID=3.18.2
PRETTY_NAME="Alpine Linux v3.18"
HOME_URL="https://alpinelinux.org/"
BUG_REPORT_URL="https://gitlab.alpinelinux.org/alpine/aports/-/issues"
~ # caddy environ
caddy.HomeDir=/root
caddy.Version=v2.7.2 => github.com/caddyserver/caddy/v2@v2.7.2 h1:QqThyoyUFAv1B7A2NMeaWlz7xmgKqU49PXBX08A+6xg=
runtime.GOOS=linux
runtime.Compiler=gc
runtime.NumCPU=4
runtime.GOMAXPROCS=4
os.Getwd=/root
HOSTNAME=REDACTED
SHLVL=1
HOME=/root
OLDPWD=/srv
PGID=100
TERM=xterm
XDG_DATA_HOME=/data
PUID=REDACTED
PWD=/root
TZ=REDACTED
This is my Dockerfile
tas
August 4, 2023, 5:20am
5
ah! I didn’t notice that I had a commit version leftover in my Dockerfile
RUN xcaddy build d7d16360d41159a3bea772c36e795bab31503897
all good now, thank you for double checking for me!
