I am setting up a new install of Zoneminder so I can see my security cameras without having to log into my network. Right now everything is internal until I can setup fail2ban and ufw on my ZM (ZoneMinder) server. I have fail2ban working if you access ZM directly but if you go through Caddy, all it sees is Caddy’s IP.
I have tried using a few different settings in my caddyfile right now I have:
https://zm.thomastech.us {
gzip
header / {
Referrer-Policy "no-referrer"
tls /srv/thomastech.us.crt /srv/thomastech.us.key
proxy / https://tt-zoneminder.thomastech.us/ {
insecure_skip_verify
websocket
I have also tried explicitly setting the header_upstream values instead of using “transparent” and nothing changes. Is this a setting I need to find in ZM/apache2 on my ZM server or am I missing something with caddy? I remember having this issue with my Home Assistant server and had to set a switch in that server’s config so it knew to “use_x_forwarded_for” is there something for apache2 like that?
Thanks for the help.
