see docker compose
Ubuntu 20 lts
Linux hostname 5.4.0-65-generic
docker-compose up -d/restart or caddy restart
version: "3.7"
image: caddy:2
- /home/user/Yotter/app:/var/www/yotter
- /home/user/Yotter/ytproxy:/var/run/ytproxy
subdomain.domain.tld {
route {
file_server /static/* {
root /var/www/yotter
reverse_proxy (/videoplayback/*|/vi/*|/a/*) unix//var/run/ytproxy/http-proxy.sock
reverse_proxy yotter:5000
I’m trying to run Yotter. If I use a simplified version of the caddyfile it works except for the youtube part
I’m trying to use the suggested nginx configuration to get it working.
server {
listen 80;
server_name <example.com>; # ChangeME
access_log off;
location / {
proxy_pass http://127.0.0.1:5000;
proxy_http_version 1.1;
proxy_set_header Connection "";
location /static/ {
root /home/ubuntu/Yotter/app/; # Change this depending on where you clone Yotter
sendfile on;
aio threads=default;
location ~ (^/videoplayback$|/videoplayback/|/vi/|/a/) {
proxy_pass http://unix:/var/run/ytproxy/http-proxy.sock;
add_header Access-Control-Allow-Origin *;
sendfile on;
tcp_nopush on;
aio_write on;
directio 512;
The configuration is accepted by caddy but it does not work ni the browser since all I get is 502
The current Caddyfile configuration is what I came up with. Since I’m getting 502 I suppose they’re getting redirected to the wrong containers/routes. I used route to try and get them in the right order since I read about the priority order “issues”
