Development: Caddy considerations when using permalinks in WordPress
n/a
n/a
n/a
n/a
n/a
The WordPress article Using Permalinks has the one and only reference in WordPress support docs to Caddy. However, the reference is for Caddy V1 so it’s out-of-date!
See post to follow.
n/a
n/a
  1. Process check: Spreading the Caddy Word - #31 by basil
Here’s the relevant extract from the article:
Pretty permalinks are available under:
  • Apache web server with the mod_rewrite module
  • Nginx using try-files, e.g. according to this tutorial
  • Hiawatha web server with UrlToolkit support enabled.
  • Lighttpd using a 404 handler or mod_rewrite
  • Caddy using rewrite, e.g. according to this tutorial
Clicking the link to the tutorial takes me to a Caddy V1 article.
I’d like to propose the following changes to the WordPress documentation team:
  1. Revise this extract to read as follows:
  • Caddy automatically in a default WordPress installation.
This is based on feedback from @francislavoie in this post Process check: Spreading the Caddy Word - #16 by francislavoie
  1. Just further down in the WP article, in the section Using “Pretty” permalinks, I propose adding the following bullet point:
This is based on feedback from @Whitestrake in this post Process check: Spreading the Caddy Word - #19 by Whitestrake
Before I submit a request to update the article, I just want to make sure that I’ve interpreted the feedback correctly and this is reflected in the proposed text amendments. Suggestions for improving the proposed text are also welcome.
Sounds reasonable :+1:, maybe mention that it’s the default behaviour of the php_fastcgi directive? idk
Will do.Thanks!
A WordPress doc update request has been submitted here Using Permalinks: Update Caddy references · Issue #8 · WordPress/Documentation-Issue-Tracker · GitHub
