1. My Caddy version (caddy -version
Caddy v1.0.4 (h1:wwuGSkUHo6RZ3oMpeTt7J09WBB87X5o+IZN4dKehcQE=)
sudo -u www-data caddy -conf /etc/caddy/Caddyfile
-or-
sudo caddy -conf /etc/caddy/Caddyfile
(tried both)
Ubuntu 18.04, no docker
see how I run caddy
d. My complete Caddyfile:
192.168.86.4:8080 {
# tls admin@example.com
root /var/www/wordpress
gzip
fastcgi / /run/php/php7.3-fpm.sock php
# Prevent malicious PHP uploads from running
rewrite {
r /uploads\/(.*)\.php
to /
rewrite {
if {path} not_match ^\/wp-admin
to {path} {path}/ /index.php?_url={uri}
When using Wordpress with Caddy, the ‘preview’ feature of Wordpress does not work,
when I switch to wp-cli’s “wp server” command it works fine.
When I say it does not work, you edit a page in wordpress, and hit ‘Preview’ in the page you are editing.
Correct behavior is a ‘preview’ of the edited page refreshes or opens in another tab with the changes you just made.
The incorrect behavior, which is happening to me, is the page refreshes or opens in another tab WITHOUT any of the edits/changes I just made.
I am suspecting a headers/caching issue or something related.
If I use the wp-cli wrapper around php -S everything works expected, so I again, suspect caching or headers issues that I don’t understand yet.
