I had all kinds of problems setting up Caddy to run Wordpress, see this post:
Now it’s running, but Wordpress tells me it can’t autoupdate neither itself nor any plugins/themes.
Is this a Caddy-related issue?
Apparently it’s not possible to save drafts or posts either…
I highly doubt that’s related to Caddy. Your user under which PHP-FPM runs is probably lacking write permissions to the wordpress plugins directories.
Ah, something more to troubleshoot.
Thanks!
I’ll look into that
That was one problem - I ended up having to set
define('FS_METHOD','direct');
in wp-config.php to get autoupdates to work.
The problem with saving posts and drafts was a completely different problem, the new “Block editor” in WP that required a different permalink setting to work for drafts and posts…
Okay, so this is solved?
Yes it’s solved!
